    Filament Sensor Pausing Print even when disabled
    Filament Monitor
    • iff7378
      iff7378 last edited by
      See the picture below from the printer console. This is the output of M591 D0.
      It correctly says disabled but it still seems to be pausing prints when outside of the allowed error range.
      Also how does the math work out to a negative percentage error? Is this related to retractions not registering correctly? I'm thinking I need to more securely mount the sensor above the extruder. Right now its just sitting on the PTFE tube about 25mm above the feed wheels.
        dc42 administrators @iff7378 last edited by
        @iff7378 I need more data, in particular firmware version(s).
        iff7378 1 Reply Last reply Reply Quote 0
        • iff7378
          iff7378 @dc42 last edited by
          @dc42 Sure thing
          M115
          FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet Ethernet 1.02 or later + DueX5 FIRMWARE_DATE: 2020-02-09b1
            @iff7378 this is recorded as having been fixed in firmware 3.2. https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-32
