    1.19 from bossa port
    Firmware installation
    • weput
      weput last edited by
      Ok.. I came from some months with the board stored…. So I clicked the erase button.
      Can someone point me to the new 1.19 procedure.? I can't make the wifi work.
        https://duet3d.com/wiki/Upgrading_to_DuetWiFiFirmware_1.19
        • weput
          I installed the main firmware with sam-ba but couldn't make it work… Now I see I have to load the wifi module firmware and then dwc on the SD card...
          Version x.17 of sam-ba ask me to lock some sectors.. What do you recommend over that?
            Yes lock them, see https://duet3d.com/wiki/Updating_main_firmware#Fallback_procedure_.233.
            • weput
              just a side note:
              DuetWebControl is needed to run the M997 successfully…
                @weput:
                just a side note:
                You can send that command from USB or PanelDue too. The USB connection will be dropped but the firmware update will proceed.
                • weput
                  sorry… forgot to update
                  https://www.youtube.com/watch?v=Kh7J2sSfA38
