    Duet With palette 2
    Third-party software
    • docfail
      docfail last edited by
      I know there are several topics covering this subject but nothing seems to work for me.
      I have a duet 2 wifi which works perfectly, and I'm trying to use octoprint on a Pi 4b to run a palette 2 (really annoying to not being able to use dwc).
      Basically I home and heat up the printer then connect octoprint (like mentioned here : https://forum.duet3d.com/topic/21022/duet-rrf-mosaic-palette-and-octoprint/6?_=1612197410142) but wen connecting octoprint I get various errors...
      Does someone have an idea, I'm loosing faith in the palette, the concept is great but using it is such a pain.
      thanks
      • percar
        percar last edited by
        What Errors are you getting
        I used this setup without issue
        Also octoprint is not too friendly making the connection to Duet
        docfail 1 Reply Last reply Reply Quote 0
        • docfail
          docfail @percar last edited by
          @percar nevermind, i tried exactly the same thing, did not changed anything, and it's printing...
          I just don't know why but it is working 😮 (not bad when its this way) .
          But thanks a lot, next I will try printing with the palette.
          Oh by the way what slicer are you using for multicolor prints ?
          percar 1 Reply Last reply Reply Quote 0
          • percar
            percar @docfail last edited by
            @docfail
            I use kisslicer, superslicer, simplify3d all the instructions are in mosaic support area
            each of the slicers have there own issues so its what works best for you
