Solved "out9" appears to always be enabled
@brendon what I actually meant was, when the board was erased and before you reinstalled the firmware, did OUT9 still turn on when you powered up or reset the board? If it did then that indicates a hardware issue.
@dc42 Sorry for the brevity in my previous response. Yes, out9 is still turned on and enabled after the board was erased but before the firmware was flashed.
