    Tabs and spaces in the G-code editor, encore
    Duet Web Control
    1
    1
    123
    • Schmartundefined
      Schmart
      Re: [DWC 3.2](gcode editor issue)
      Hi, I found the older topic referenced above mentioning that tabs should be replaced by spaces in the editor. However, while working intensively with conditional G-code/meta commands in the last couple of weeks (DWC 3.4.0 beta 5/6), I noticed this does not happen?
      I have to manually check the code with Visual Studio Code (search for \t) to prevent RRF complaining that spaces and tabs are mixed.
      Take the following code as a start:
      while {false}
      echo "Tab before line indent"
      echo "Selected line level 1 indent"
      echo "Selected line level 2 indent"
      • When I put the cursor in front of line 2 and press [Tab] → a tab character is inserted.
      • When I select line 3 with [Shift]+[Down] and press [Tab] → two spaces are inserted.
      • When I select line 4 with [Shift]+[Down] and press [Tab] twice → a tab character is inserted.
      So it looks like this now:
      I would like that the built-in DWC editor converts indents into either spaces or tabs, but that it prevents a mix of both.
      P.S. I think two spaces are a good alternative to a space, but I know there's a camp that would prefer four spaces or tab characters only. So ultimately, a user setting for this would be nice.
      Creality CR-20 Pro with a Duet 2 Maestro, 3Dfused X+Z-axis rail kit, HIWIN-based DIY solution for the Y-axis, E3D Hemera, working ST7565 MiniPanel and various other small hardware improvements.
