    Drive Polarity/Direction missing from Object Model
    Gcode meta commands
    • jmb10101undefined
      jmb10101
      I'm not seeing the drive polarity of the associated motors for any axis or extruder in the object model. Is this information currently available to read? I'm using Duet version 3.3 and Duet Web Control 3.3.0 with the object model plugin. Also, is there updated documentation on using and interpreting the object model (http requests, value descriptions, etc.)?
      • Phaedruxundefined Phaedrux moved this topic from Duet Web Control
        New keys are being added to the object model with each release as it is developed. You may wish to update to 3.4 betas to see what else new has been added. You can get a read back of the object model from the plugin or by sending M409
        https://duet3d.dozuki.com/Wiki/M409
        https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
