    Revert Firmware
    Using Duet Controllers
    • chichirodundefined
      chichirod
      Im trying to revert back from
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
      Duet WiFi Server Version: 1.23
      to
      Board: Duet WiFi 1.02 or later (duetwifi102)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.04 (2019-11-01b1)
      but ive downloaded the 2.05 Duet2CombinedFirmware.bin and tried installing but I get this error:
      Error: M997: In-application programming binary "0:/firmware/Duet2_SDiap32_WiFiEth.bin" not found How do I fix this. Please
      chrishammundefined chichirodundefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @chichirod
        @chichirod Get the missing file from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.3, upload it on the System Files page, and try again.
        Duet software engineer
          chichirod @chichirod
          @chichirod that worked. Thank you
