please help me blv setting
@martin7404 the hotend before I had e3dv6 and a different probe the z of t8 metal and extruder bmg changed to extruder orbitor and I had the same problem and when I touch the adjustment of the belt I have not much difference
@martin7404 I wonder if the problem is not related to that because I print a 20x20x20 cube all the dimensions full and on the graphics it is not going
@martin7404
here it is a graphic of someone who printed the same cube as me, we see that the lines are always the same -
@sgk
do you know why the time of each layer is not the same while the cube is the same everywhere -
@sgk this is my cube
@sgk If you are sure Your bed is level and there is no wobble in the Z axis
then it is extrusion calibration and temperatures -
@martin7404
I do before each print g29 -
@sgk ok can you share your bed graph
@sgk p.s speed, accel , jerk ?
@martin7404
I can't find where the graphics are -
@sgk On DWC heightmap
@martin7404 RepRapFirmware height map file v2 generated at 2021-12-17 13:36, min error -0.140, max error 0.223, mean 0.055, deviation 0.129
axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
X,Y,20.00,270.00,20.00,270.00,-1.00,240.00,240.00,2,2
0.076, 0.223
0.062, -0.140 -
@sgk
@sgk it is ok, but I will suggest you do at least 16 points map
@martin7404 ok 16
@martin7404 how do you manage to put in 16?
@sgk ; bed.g
; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
M291 P"Probing mesh grid process started" R"Probing.." S1 T2
G28 ; home all axis bb
M671 X-30.0:364.0 Y175.0:175.0 S5.0 ;bed compensation
G30 P1 X5 Y150 Z-99999
G30 P0 X300 Y150 Z-99999 S2
G90 ; absolute positioning bb
M557 X20:270 Y20:270 S240 ; Define mesh grid
G29 S0 ; Probe the bed and save height map to file
M374 ; Save calibration data. Default is sys/heightmap.csv
M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
; Probe the bed at 4 points
;G30 P0 X10 Y10 H0 Z-99999 -
This post is deleted! -
@sgk Hey friends after changing the thermistor probe for a Semitec 104GT-2 the lines are now straight horizontally but the vertical lines are shifted and lack of filament as we see in the photos? Any ideas folks?
