Problems compiling Firmware
  • Hello,
    First i want to thank all the people that work on the Duet elctronics ant the RepRapFirmware for making such a great product.
    I'm a mechatronics student from germany and want to help by adding features and improving the firmware.
    I followed the buildinstructions from the github page. The only difference is, i have a newer version of the Arduino IDE, but that shouldn't be a problem.
    I imported:
    -CoreNG
    -DuetWifiSoketServer
    -RepRapFirmware
    into eclipse and changed to path of the gcc cross compiler to the correct one.
    The only problem i have now is that when i want to build CoreNG it tells me sam4e.h is missing.
    Did i miss any include or something?
    Thanks for any help.
    [[language]]
    16:06:06 **** Incremental Build of configuration SAM4E8E for project CoreNG ****
    make all
    'Building file: ../variants/duetNG/exceptions.c'
    'Invoking: Cross GCC Compiler'
    arm-none-eabi-gcc -D__SAM4E8E__ -DUDD_ENABLE -DUDD_NO_SLEEP_MGR -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\cores\arduino"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf" -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\utils"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\utils\header_files"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\utils\preprocessor"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\utils\cmsis\sam4e\include"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\dmac"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\efc"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\hsmci"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\pio"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\pmc"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\spi"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\sam\drivers\usart"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\utils"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\clock"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\ioport"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\sleepmgr"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\usb"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\usb\udc"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\usb\class\cdc"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\common\services\usb\class\cdc\device"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\asf\thirdparty\CMSIS\Include"
    -I"C:\Users\*USER*\Documents\Workspace_duet\CoreNG\variants\duetNG"
    -O2 -Wall -c -std=gnu99 -mcpu=cortex-m4 -mthumb -mfpu=fpv4-sp-d16 -mfloat-abi=softfp -ffunction-sections -fdata-sections -nostdlib -MMD -MP
    -MF"variants/duetNG/exceptions.d"
    -MT"variants/duetNG/exceptions.o"
    -o "variants/duetNG/exceptions.o"
    "../variants/duetNG/exceptions.c"
    In file included from ../variants/duetNG/exceptions.c:57:0:
    ../variants/duetNG/exceptions.h:50:19: fatal error: sam4e.h: No such file or directory
     #include "sam4e.h"
    compilation terminated.
    make: *** [variants/duetNG/exceptions.o] Error 1
    You should have that file in folder CoreNG\asf\sam\utils\cmsis\sam4e\include.
  • Yes, i have the sam4e.h in my CoreNG\asf\sam\utils\cmsis\sam4e\include folder.
    The directory is also listed in the includes of the CoreNG project.
    Is there something else that could cause this problem?
  • I found the problem, there was a non standard ASCII character in the include path.
Locked
