Layer times / count oddities
Beta Firmware
  • undefined
    rjenkinsgb
    Edit - the short layer times are a slicer bug or oddity, not a Duet bug.
    The layer count appears to be a Duet bug - see the next post.
    Times:
    It just started showing the same thing on the print I'm doing now - after posting the problem, of course - so I compared the gcode line counts at the layer steps.
    Whilst layer height is set to 0.2mm, at certain points the slicer add a 0.1mm layer and only fills in a small amount of support material, which means a very short layer time.
    I have also seen this zero time effect mentioned in other threads.
    Robert J.
    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
    • undefined
      rjenkinsgb
      OK, there is definitely a bug in the Duet side relating to layers.
      This is what DWC is presently showing me:
      The same info is given on the Paneldue for estimations.
      Note the layer count: 230 of 199; however the gcode file shows 268 layers, with this at the last layer change:
      ;; AFTER_LAYER_CHANGE:268,39.8
      The job information shows total height 39.8 and 0.2mm layers so that part is correct.
      I cannot find anything in the gcode file that gives a layer count, other than the layer change numbers - so presumably the layer count is read or calculated in the Duet system?
      Robert J.
      • undefined
        If the slicer doesn't provide a layer count DWC calculates the layers from the total height and layer changes, which can get confused by the shorter layer heights.
        1 out of 3
