Is M84 idle timeout state reflected in object model
I've noticed that if I send M84 with no S parameters, then all axis become unhomed, as expected.
If I send an axis, then the axis becomes unhomed immediately, regardless of the S parameter (not expected)
If I set a short timeout say M84 S5, then the axes don't become unhomed after sitting idle (not sure what to expect).
In all cases I can't find any indication in the object model of a reduced current.
move.axes[0].percentCurrent responds to M913 commands as expected, but nothing seems to show that the motor idle timeout from M84 and M906 is in effect.M906 X1100 Y1100 Z1100 E1400 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S600 ; Set idle timeout at 10 minute
