    unable to calibrate rotating magnetic sensor
    Filament Monitor
    • c310undefined
      c310
      finally, i have came to a point where sensor is nedded, but i am not able to calibrate / configure it.
      config is:
      M591 D0 P3 C"e0_stop" R03:120 E3.0 S0
      when printing sensor led is flashing red / green
      but console shows wild message
      (more readable 🙂
      06.01.2022, 15:23:51	M591 D0
      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 28.80mm/rev, allow 3% to 120%, check every 3.0mm, version 3, mag 130 agc 97, measured sensitivity infmm/rev, min -2147483648% max 2147483647% over 519.8mm
      06.01.2022, 15:21:54	M591 D0
      Duet3D rotating magnet filament monitor v3 on pin e0stop, disabled, sensitivity 28.80mm/rev, allow 3% to 120%, check every 3.0mm, version 3, mag 130 agc 97, measured sensitivity infmm/rev, min 0% max 0% over 64.7mm
      min and max numbers are crazy. Duet2WiFi RRF 3.3
      please help me to configure the sensor! thank you in advance!
        I would say double check assembly for starters.
