    List of variables
    Gcode meta commands
    • Vladimir_Uundefined
      Vladimir_U
      hello. I wanted the printer to emit a signal when successfully connected to a wi-fi network. I know about how to do it. But I don't know where to look for triggers that would trigger these actions. Where can I find a list of variables on printer/firmware events and states? Sorry, I'm just learning RRF
        Vladimir_U
        Is this data taken from the so-called "object model"?
        https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation
        Am I on the right way?
        • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
          Have a look here as well
          https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands
          Using the object model to get the state of the printer and conditional gcode to check it on a regular interval in the daemon.g file would probably get you what you want.
