    DCS (Browser) not opening site doesnt exisť Duet 3 mini 5+
    Duet Web Control
    • PalyNoundefined
      PalyNo
      Hi there I am asking for help , I connected my duet3mini5+ to wifi (at least it says that) Green is always on and I cannot acces DCS trought IP adress Its says that Ip doesnt respond . I am following the guide instructions an I get stuck what problem coul it bee ? I already conected trought another browser in another computer but still nothing. Into browser I am typing this ip adress 192.168.70.42 it is still the same and isnt changing when connecting and disconecting.
      Both computer and duet ar conected on same wifi, I have NO acess to ethernet.
      M552
      WiFi module is connected to access point Office FreeWiFi2, IP address 192.168.70.42<LF>ok<LF>
      M20 P"/"
      Begin file list<LF>overlays<LF>kernel7.img<LF>kernel.img<LF>bcm2710-rpi-3-b-plus.dtb<LF>kernel7l.img<LF>kernel8.img<LF>bcm2708-rpi-b-plus.dtb<LF>bcm2708-rpi-b-rev1.dtb<LF>bcm2708-rpi-b.dtb<LF>bcm2708-rpi-cm.dtb<LF>bcm2708-rpi-zero-w.dtb<LF>bcm2708-rpi-zero.dtb<LF>bcm2709-rpi-2-b.dtb<LF>bcm2710-rpi-2-b.dtb<LF>cmdline.txt<LF>config.txt<LF>bcm2710-rpi-3-b.dtb<LF>bcm2710-rpi-cm3.dtb<LF>bcm2711-rpi-4-b.dtb<LF>bcm2711-rpi-400.dtb<LF>bcm2711-rpi-cm4.dtb<LF>COPYING.linux<LF>start.elf<LF>start_cd.elf<LF>start_db.elf<LF>start_x.elf<LF>fixup.dat<LF>fixup_cd.dat<LF>fixup_db.dat<LF>fixup_x.dat<LF>bootcode.bin<LF>start4.elf<LF>start4cd.elf<LF>start4db.elf<LF>start4x.elf<LF>fixup4.dat<LF>fixup4cd.dat<LF>fixup4db.dat<LF>fixup4x.dat<LF>LICENCE.broadcom<LF>issue.txt<LF>filaments<LF>gcodes<LF>macros<LF>menu<LF>sys<LF>www<LF>firmware<LF>System Volume Information<LF>End file list<LF>ok<LF>
      M20 P"/www"
      Begin file list<LF>fonts<LF>css<LF>js<LF>img<LF>favicon.ico.gz<LF>manifest.json.gz<LF>index.html.gz<LF>service-worker.js.gz<LF>precache-manifest.60203ed55805000c1d8c35cfc138f4cf.js.gz<LF>End file list<LF>ok<LF>
        Can you change your terminal software to show correct line endings?
        If you're using YAT see here
        Then send M122 and post the results here.
        Are you able to ping the address it claims to have?
        What IP address does your computer have?
