    3.4RC1 SBC upgrade error
    Beta Firmware
    • resamundefined
      resam
      I was running 3.3 from the stable repos.
      I changed it to unstable, did apt update + apt upgrade.
      It went through fine, flashed new firmware.
      But I saw this error message while it was installing all new packages:
      Reading changelogs... Done
      (Reading database ... 51829 files and directories currently installed.)
      Preparing to unpack .../0-duetsoftwareframework_3.4-rc1_armhf.deb ...
      Unpacking duetsoftwareframework (3.4-rc1) over (3.3.0) ...
      To delete the "dsf" user run as root: userdel --force dsf
      Preparing to unpack .../1-duettools_3.4-rc1_armhf.deb ...
      Unpacking duettools (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../2-duetpimanagementplugin_3.4-rc1_armhf.deb ...
      Error:
        An assembly specified in the application dependencies manifest (PluginManager.deps.json) was not found:
          package: 'runtimepack.Microsoft.NETCore.App.Runtime.linux-arm', version: '6.0.1'
          path: 'System.Net.Quic.dll'
      Unpacking duetpimanagementplugin (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../3-duetpluginservice_3.4-rc1_armhf.deb ...
      Unpacking duetpluginservice (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../4-duetcontrolserver_3.4-rc1_armhf.deb ...
      Unpacking duetcontrolserver (3.4-rc1) over (3.3.0) ...
      To delete "gpio" group run as root: groupdel gpio
      Preparing to unpack .../5-duetruntime_3.4-rc1_armhf.deb ...
      Unpacking duetruntime (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../6-duetwebserver_3.4-rc1_armhf.deb ...
      Unpacking duetwebserver (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../7-duetwebcontrol_3.4-rc1_all.deb ...
      Unpacking duetwebcontrol (3.4-rc1) over (3.3.0) ...
      Preparing to unpack .../8-reprapfirmware_3.4-rc1-2_all.deb ...
      Unpacking reprapfirmware (3.4-rc1-2) over (3.3.0-1) ...
      @chrishamm anything to be concerned about?
      So far the board and SBC seem to run fine - but I haven't started a print yet.
      • chrishammundefined
        chrishamm administrators @resam
        @resam No, there is nothing to be concerned about - I saw this with an earlier beta but didn't see any side effects. I think duettools is installed before duetruntime is updated and an install script from duetpimanagementplugin attempts invoke a program from it which loads an outdated assembly. I'll check again if I can fix it by adding a new dependency from duettools to the correct duetruntime version.
        Duet software engineer
