    Turn laser pointer off
    Laser Cutters
    • Kapoueundefined
      Kapoue
      I have installed a Sculfun S9 Laser module and I am able to use it but I could like to be able to enable the dot on a low power to position my laser correctly.
      I am able to turn it on mith the commands:
      M950 P0 C"!exp.heater3" Q1000 ; allocate GPIO port 0 to heater3 on expansion connector, 500Hz
      M42 P0 S0.01 ; set 1% PWM duty on GPIO port 0
      But after that, I am not able to use the laser anymore. It always say hat "the pin is already assigned" so I have tried to unassign it by using
      M950 P0 C"nil"
      Without success.
      How could I fix it please?
      Regards,
        Phaedrux Moderator @Kapoue
        @kapoue said in Turn laser pointer off:
        M950 P0 C"nil"
        Without success.
        What happens when you send that command?
        What do you get if you send M950 P0 by itself before and after?
        Firmware version?
