    M915 not triggering under any circumstances
    CNC
    625
    • thomas.weissundefined
      thomas.weiss
      Hey,
      I have a Duet 3 Mini 5+. I'm building a small CNC machine and I am trying to implement stall detection for safety reasons and for some specific situations. Homing is done via usual endstop switches.
      For a start, I am trying to get this to work on the X-axis only, since this is the easiest to reach and test for me.
      Here is one part of my config.g
      The X motor is at 0.3 and I already lowered the currents from 1500 to 1000 mA.
      I tried a lot of different parameters for the M915 command, using negative and positive sensitive values and also decreased and increased to H-parameter from 100-400.
      I manually held the spindle in a test code file so it loses steps and was hoping for some kind of log in the webcontrol console or the USB debugging interface. So far, I haven't seen any hint on stall detection being active.
      Here is the part from the config.g that I think is relevant:
      M569 P0.1 S1
      M569 P0.0 S0
      M569 P0.3 S0
      M569 P0.2 S1
      M584 X0.3 Y0.0:0.2 Z0.1 ; set drive mapping
      M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
      M92 X666.67 Y666.67 Z1000.00   ; set steps per mm
      M566 X1000.00 Y1000.00 Z800.00      ; set maximum instantaneous speed changes
      M203 X3000.00 Y3000.00 Z3000.00 ; set maximum speeds (mm/min)
      M201 X300.00 Y300.00 Z200.00      ; set accelerations (mm/s^2)
      M906 X1000 Y1500 Z1100          ; set motor currents (mA)
      M915 X S1 R1 F1 H200; Stall detection
      What am I missing here? What information would I need to provide to get some guiding into the right direction?
      I am using this Nema 17 for the X-Axis on 24V:
      And here is the full config.g to close it off:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Wed Nov 03 2021 10:22:11 GMT+0100 (Mitteleuropäische Normalzeit)
      ; Enable eventlogging
      M929 P"eventlog.txt" S1
      G90                              ; send absolute coordinates...
      M83                              ; ...but relative extruder moves
      M550 P"pt1"                		 ; set printer name
      M552 P0.0.0.0 S1                 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                       ; enable HTTP
      M586 P1 S1                       ; enable FTP
      M586 P2 S0                       ; disable Telnet
      M575 P1 B57600 S0				 ; disable checksum requirement on the panel due UART
      M569 P0.1 S1                     ; physical drive 0.1 goes forwards
      M569 P0.0 S0                     ; physical drive 0.2 goes forwards
      M569 P0.3 S0                     ; physical drive 0.3 goes backwards
      M569 P0.2 S1                     ; physical drive 0.4 goes backwards
      M566 X1000.00 Y1000.00 Z800.00   ; set maximum instantaneous speed changes (mm/min)
      M906 X1000 Y1500 Z1100           ; set motor currents (mA) and motor idle factor in per cent
      ; Stall detection
      M915 X S0 R1 F1 H100;
      M208 X0 Y0 Z0 S1                 ; set axis minima
      M208 X150 Y100 Z55 S0            ; set axis maxima
      M574 X1 P"^io4.in"           ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !^io0.in
      M574 Y1 P"^io2.in+^io3.in"   ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^io1.in
      M574 Z1 P"^io1.in"           ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !^io2.in
      M558 P0 H5 F120 T6000            ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:180 S20         ; define mesh grid
      M140 H-1                         ; disable heated bed (overrides default heater mapping)
      M950 C"out0" P0 ; setup laser to virtual outputpin 0
      M563 P0 S"spindle"         ; define tool 0
      M453 ; switch to cnc mode
      T0                               ; select first tool
        dc42 administrators @thomas.weiss
        @thomas-weiss are you definitely running firmware 3.3 (or 3.4rc1)?
        Have you set up your homing files to do a suitable stealthChop tuning move, before trying to use stall detection? The online configuration tool doesn't yet generate this.
        thomas.weissundefined 1 Reply Last reply Reply Quote 0
          thomas.weiss
          @dc42 Hey there!
          WebControl says that I am running "RepRapFirmware for Duet 3 Mini 5+ 3.3 (2021-06-15)".
          All changes I did are in the config.g file - I haven't edited my homing files. I went through this link a couple of times and interpreted it as if I wouldn't need to change anything outside of my config.g if I didn't want to use sensorless homing.
          My only goal would be to detect if steps have been lost and run a custom macro or in some way send a message to USB so I can make a warning message for my frontend.
            thomas.weiss @dc42
            @dc42 So I did more research and found one of your replies from Dec. 2020 where you explain the stealth chop tuning move:
            It reads:
            • Execute a tiny move (1 or 2 microsteps) away from the homing direction.
            • Pause for 100ms using G4.
            • Execute a small move away from the homing direction, e.g. 10mm.
            • Execute the homing move.
            Trying to adapt this, I edited my homex.g file to like this:
            ; HOME X
            G91
            G1 H2 X0.05       ;(StealthChop tuning) Tiny move away from homing direction
            G4 100            ;(StealthChop tuning) Wait 100 ms
            G1 H2 X10         ;(StealthChop tuning) Smaller move away from homing direction
            G1 H1 X-305 F2000 ;Move quickly to X axis endstop and stop there (first pass)
            G1 H2 X5 F3000    ;Go back a few mm
            G1 H1 X-305 F500  ;Move slowly to X axis endstop once more (second pass)
            Apart from the usual configuration, my config.g includes these commands:
            M569 P0.1 S1 D3 V10              ; physical drive 0.1 goes forwards
            M569 P0.0 S0 D3 V10              ; physical drive 0.2 goes forwards
            M569 P0.3 S0 D3 V10              ; physical drive 0.3 goes backwards
            M569 P0.2 S1 D3 V10              ; physical drive 0.4 goes backwards
            M906 X1500 Y1500 Z1100           ; set motor currents (mA) and motor idle factor in per cent
            M915 X S1 R2 F0 H200;            ; Enable stall detection
            With this setup (M569 with V10), the machine sounds totally different / vibrating while moving. It also kind of stalls itself (without M915 reacting) at currents that worked perfectly fine before (with M569 at V100 for example). I expect that this means, that it's in stealthchop now and doesn't switch to spreadcycle which in return wouldn't allow stall detection, right?
            My expected outcome would be standard homing with hardware switches, start a job from the SD card, make the X motor lose steps manually, have M915 trigger a pause (R2).
            What am I missing? It's like stall detection doesn't exist.
              @thomas-weiss the first step ("tiny move") was to energise the motor. In firmware 3.3 and later you can use M17 followed by the axis letter(s) you want to energise.
              The V10 parameter on your M569 commands will force the driver to stay in stealthChop modes at all speeds. This is not a good idea unless you limit the top speed to values at which stealthChop performs well.
              The 10mm move away from the homing direction, and the first homing move, should be made at a reasonable speed, for example 4000mm/sec for a typical X or Y axis.
                thomas.weiss @dc42
                @dc42 Alright. Enabling motors with a M17, waiting for 100ms , then moving by 10mm with F4000. I included this right at the start of my homing files.
                M17;
                G4 P100;
                G1 H2 X10 F4000;
                I changed the V10 into a V100. Now the motor movements sound good again, but still - absolutely no hint of a stall detection triggering when I tun a job and press my hand against the carriage until it loses sterps.
                Can I somehow see if the stealthchop tuning move was "detected" and that it's actually trying to listen for stalls?
                Little update - this seemed to help a tiny bit. I also made a testfile that moves left and right with F4000. I managed to get a warning for driver 3 stalling, but haven't been able to get another one with the next hour of trying. This warning just randomly popped up.
                  thomas.weiss
                  Since I can't edit my last post anymore...
                  For the M915 I tried H-paramter from 1 - 400 and S parameters from -50 to 50.
                  With the following setup I got the only warning overall but I wasn't able to reproduce it at all anymore.
                  Warning: Driver(s) 3 stalled at Z height 0.00
                  Herer is my current config.g
                  M569 P0.1 S1 D3 V100             ; physical drive 0.1 goes forwards
                  M569 P0.0 S0 D3 V100             ; physical drive 0.2 goes forwards
                  M569 P0.3 S0 D3 V100             ; physical drive 0.3 goes backwards
                  M569 P0.2 S1 D3 V100             ; physical drive 0.4 goes backwards
                  M203 X4000.00 Y4000.00 Z4000.00  ; set maximum speeds (mm/min)
                  M201 X400.00  Y400.00  Z400.00     ; set accelerations (mm/s^2)
                  ; Stall detection
                  M915 X S1 R1 F1 H10;
                  And here is my homeall.g
                  ; homez.g
                  ; called to home the Z axis
                  G54
                  T-1 ; deselect tool
                  G91;
                  M17;
                  G4 P100;
                  G1 H2 X10 F4000;
                  G4 P100;
                  ; HOME Z
                  G91              ; relative positioning
                  G1 H1 Z-90 F2000 ; move Z down until the endstop is triggered
                  G1 H2 Z3 F2000 ; move Z up a little
                  G1 H1 Z-5 F200 ; move Z down until the endstop is triggered
                  G92 Z0           ; set Z position to axis minimum (you may want to adjust this)
                  G90
                  G0 Z55 ; raise Z axis
                  G91
                  ; HOME X
                  G1 H1 X-305 F2000 ; move quickly to X axis endstop and stop there (first pass)
                  G1 H2 X5 F3000    ; go back a few mm
                  G1 H1 X-305 F500  ; move slowly to X axis endstop once more (second pass)
                  ; HOME Y
                  G1 H1 Y-185 F2000 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 H2 Y5 F3000    ; go back a few mm
                  G1 H1 Y-185 F500  ; move slowly to Y axis endstop once more (second pass)
                  G90               ; absolute positioning
                  G1 X80 Y50 Z30 F3000 ; Go to machine center
                  The gcode I am running from SD for testing looks like this:
                  G90
                  G64
                  M3 S12000
                  G01 X20 Y50 Z0 F4000
                  G01 X100 Y50 Z0 F4000
                  ; Many more of these moves ...
                  M5
                  M0
                  While the machine is moving, I am blocking the X axis with my hands, which makes an interesting sound when losing steps. After this, it just keeps going shifted by a few millimeter, no logs, no pausing, no execution of rehome.g (tried multiple R-parameters).
                  What am I missing?
                  dc42undefined 1 Reply Last reply Reply Quote 1
                    @thomas-weiss when you run M569 P0.1 with no other parameters (and similarly with P0.0, P0.2 and P0.3) what speed after "tpwmthrs 100" does it give in the response?
                    PS - the TMC2209 needs at least 130ms standstill time in the tuning procedure, so change G4 P100 to G4 P150.
                      thomas.weiss @dc42
                      23.2.2022, 13:08:12	M569 P0.3
                          Drive 3 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 100 (11.2 mm/sec), pwmScaleSum 22, pwmScaleAuto 3, pwmOfsAuto 41, pwmGradAuto 12, pos 168
                      23.2.2022, 13:08:11	M569 P0.2
                          Drive 2 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 100 (11.2 mm/sec), pwmScaleSum 46, pwmScaleAuto 0, pwmOfsAuto 100, pwmGradAuto 27, pos 168
                      23.2.2022, 13:08:10	M569 P0.1
                          Drive 1 runs forwards, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 100 (7.5 mm/sec), pwmScaleSum 35, pwmScaleAuto 1, pwmOfsAuto 91, pwmGradAuto 30, pos 24
                      23.2.2022, 13:08:04	M569 P0.0
                          Drive 0 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 100 (11.2 mm/sec), pwmScaleSum 43, pwmScaleAuto 1, pwmOfsAuto 90, pwmGradAuto 24, pos 680
                      Those are P0.0 to 0.3. So it's 11.2mm/s for X and Y and 7.5 mm/s for Z.
                      What are those speeds exactly?
                      (I'll switch the delay to 150 then - thanks!)
                        @thomas-weiss those speeds are the speeds at which the drivers will switch to spreadyCycle mode. So at speeds higher than those, the driver won't detect stalls.
                          thomas.weiss @dc42
                          @dc42 Thats pretty interesting. Through changing the delay and also lowering the V parameter, I am slowly starting to get stalls detected (interestingly, it's now audibly skipping steps by itself in some situations where it wasn't before).
                          So ... as soon as my driver switches over to spreadcycle, I can't detect any more stalls (by design). This means, that I would need to lower the M569 Vnnn until M569 P0.3 gives me a mm/s value that's higher than my fastest milling speed so it'll stay in stealthchop.
                          I tried lowering the V parameter before, which made the whole machine incredibly loud and shaky.
                          So technically: I need to decide if I want stall detection on a loud, shaky, slow machine (stealthchop) or use spreadcycle but lose the ability for stall detection?
                          Alright. I just did some testing. Setting M569 to V20-V50 makes it trigger stalls, but the motors seem to be incredibly weak and loud even at 2200 mA current. They are basically just stalling themselves in an aircut without doing any actual milling.
                            @thomas-weiss said in M915 not triggering under any circumstances:
                            I'm not really surprised. When the driver run in stealthChop mode, it switches to voltage-controlled mode, so that the current is reduced and the motors are quieter. The ability of the motor to respond to large increases in load is compromised. For example, when 3D printing if the nozzle hits a blob or overhang, missed steps are more likely if the driver is operating in steathChop mode.
                            In a milling machine the difference in load between homing (when the tuning cycle is done) and milling is much greater than the load change in a 3D printer. So I am not surprised that stealthChop mode doesn't work well for milling.
                            Additionally, stall detection doesn't work well at low motor speeds, because the back emf due to rotation isn't high enough to distinguish reliably from the other voltage drops in the motor.
                            Drivers that do stall detection in spreadCycle mode (such as the TMC2660 on the Duet 2, or the TMC5160 on Duet 3 MB6HC) may be more suitable for stall detection in a milling machine; however the low motor speed might still make it unreliable.
