    Documentation suggestions
    Documentation
    • mikeabuilderundefined
      mikeabuilder
      Just got redirected to the Duet3D documentation form the wiki. Nice work. I have an editorial comment and two content suggestions.
      Editorial comment - It would be nice to be able to hide the navigation column on the left side of the page. That column and the page content column together take up about a third of the width of the window.
      Two suggestions on the meta commands page.
      1. It would be great to have a definition of "code block". I've wondered in the past and today, through trial and error, I found that an indented set of text (in a loop or if statement) is a unique code block. I was declaring variables in one and wondering why the variables were not available later, outside the if statement.
      2. A comment somewhere that if you are writing macros in a windows OS, set the EOL to be Linux-style (LF only). Windows default (CR LF) written macros work, but error messages count the CR and LF as two lines, so all line numbers were multiplied by 2.
      droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • mikeabuilderundefined mikeabuilder referenced this topic
      • Phaedruxundefined Phaedrux moved this topic from Gcode meta commands
        droftarts administrators @mikeabuilder
        @mikeabuilder I've added a notes section to the Meta Gcode Commands page, and added your second suggestion there. I'll check with @dc42 regarding the first.
          mikeabuilder
          Thanks Ian. I like the idea of a notes section for collecting little bits of useful info. And apologies for reading your username, hearing "Dro farts" in my head, and wondering who Dro is. 🙂
            @mikeabuilder it's actually 'Dr of tarts'. I spent a long time in GUI clinics. And got a masters in baking.
              dc42 administrators @mikeabuilder
              @mikeabuilder re#2, are you running in standalone or SBC mode? In standalone mode at least, LF and CRLF should behave the same.
                mikeabuilder
                @dc42 - I'm running in standalone mode. To demo my observation I made two files (fail_file_CRLF.g fail_file_LF.g attached) with a bad command on line 3. One file was saved with windows EOL (CR LF) and the other with Linux EOL (LF only).
                I uploaded both to my macro directory and when I run them I get the following error messages:
                LF only - calls out a problem on line 3 as expected.
                CRLF file - calls out problem on line 5. It's counting one line for the CR and one line for the LF on each of lines 1 and 2, so it thinks the error on line 3 is really line 5.
