    Help installing self built RRF 3.3
    Firmware installation
    • pjl
      pjl last edited by pjl
      Hello forum dwellers,
      Disclaimer: I have never used eclipse, never built RRF until today, barely know anything about project structure and so on.
      So I'm learning to build RRF (for duet3) so that I can edit it later on. I followed the guide on github, got everything to build, so far so good. But the result of building RRF is a folder full of .s .su .o .d files (not a clue what this format is or what to do with them), I also see Duet3Firmware_MB6HC.bin .elf and .map files along with some source files.
      In short, I'm lost here, this resembles nothing from the prebuilt firmware files that are available for download, what do I need to put this stuff (and what stuff) onto my duet board?
      Thank you for your patience,
      Kind regards,
      P
        dc42 administrators @pjl last edited by
        @pjl the Duet3Firmware_MB6HC.bin file is the firmware file, the same name that you will find in the prebuilt firmware.
        pjl 1 Reply Last reply Reply Quote 0
        • pjl
          pjl @dc42 last edited by
          Thank you @dc42, well I feel pretty dumb right about now.
          I was expecting more things after looking at firmware update instructions. What about the IAP binary? "programming the firmware" sounds kinda important as mentioned in the docs.
            dc42 administrators @pjl last edited by dc42
            @pjl you should be able to use the standard IAP binary, assuming that you haven't modified the IAP functionality in your fork of RRF. The IAP is built from a separate Eclipse project, DuetIAP.
