    Plugin Assistance
    Plugins for DWC and DSF
    • oozeBot
      oozeBot last edited by oozeBot
      We are exploring the use of plugins instead of rebuilding DWC and have a few questions. Is it possible for a plugin to act on the upload of a gCode job file? Similar to how DWC acts on uploading a system file and prompts to install. If so, does anyone have any pointers on how to implement?
      What we want to create is a pre-processor which automatically runs a script on the SBC on all jobs when uploaded by calling a custom mCode with the filename and path as the parameter. This might get tricky if uploading a zip file..
      Another idea would be a right click context menu which calls the script (per file) when selected.
      MintyTrebor pjl 2 Replies Last reply Reply Quote 0
      • MintyTrebor
        MintyTrebor @oozeBot last edited by MintyTrebor
        @oozebot Look into @contextmenu for right click menus/actions. BtnCmd is riddled with right click menus, and it's what I use.
        psudo example :
        <v-btn @contextmenu="doMenu($event)"></v-btn>
        doMenu(e){
           e.preventDefault(); //prevents the standard right click menu from appearing
           whatever else you need....
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        • pjl
          pjl @oozeBot last edited by
          @oozebot hi, did you ever come to a solution for this? I was thinking to try and use execonmcode to start the plugin when an Mcode is called in the print gcode file, but maybe something even simpler is possible..
          oozeBot 1 Reply Last reply Reply Quote 0
          • oozeBot
            oozeBot @pjl last edited by
            @pjl Not yet, but moving a lot of our custom code to a plug-in is still our plan - we just had to prioritize other things ahead of it. Hopefully, when we revisit it, there will be many more examples out there for us to learn from.
