    Solved Building RepRapFirmware failed
    Firmware developers
    • Mohamed
      Mohamed last edited by
      Hoi,
      I'm trying to build RepRapFirmware3.3 using 3.3-dev branch. I followed the instruction on https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware installing all required tools.
      When i open eclipse:
      and build, i get the following error's:
      Could someone help me?
      Thanks
        dc42 administrators @Mohamed last edited by
        @mohamed although the branches appear to be correct (they are all origin/3.3-dev) some of the files are not. There is no file CoreTypes.h in the 3.3-dev branch of CoreNG; and there is no file RRF3Common.h in the 3.3-dev branch of CANlib. I think you have a mixture of files from 3.3-dev and from later branches.
        Mohamed 1 Reply Last reply Reply Quote 0
        • Mohamed
          Mohamed @dc42 last edited by Mohamed
          @dc42 Thank you!It works now. git clone the right branch now.
          • Topic has been marked as a question  dc42 dc42
          • Topic has been marked as solved  dc42 dc42
