    Maestro issue updating from 3.3 to 3.4
    Firmware installation
    75
    • iaTa
      iaTa last edited by
      I updated my Maestro from 3.2.2 to 3.3 the other day and it all went perfectly.
      I updated from 3.3 to 3.4 today by uploading the Duet2and3Firmware-3.4.0.zip via the webUI and it hung on installing firmware update. I left it for a good 20 mins but no response from the webUI. Rebooted and I'm now unable to ping the board. I tried going back to the 3.3 firmware and still no response.
      I noticed that there is no DuetMaestroIAP.bin file in the 3.4 release. Could this have caused an issue whilst installing the 3.4 firmware?
      Any tips on getting this sorted?
        How did you update to 3.3? Did you upload the full zip file?
        As far as I can see there hasn't been a Duet2_SDiap32_Maestro.bin file in any of the 3.4 beta releases. Is that file present in your firmware folder?
        Also note the change from the bin files going in the sys folder to now having a dedicated firmware folder starting with 3.3
        iaTa 1 Reply Last reply Reply Quote 0
        • iaTa
          iaTa @Phaedrux last edited by iaTa
          Yes by uploading the full zip.
          There is a Duet2_SDiap32_Maestro.bin file in the final 3.4 release today but no DuetMaestroIAP.bin.
          I've tried booting with 3.4 firmware along with both of the above, former from 3.4 and latter from 3.3. I've also tried booting with 3.3 with all the bin files in the firmware folder and second copies of Duet2_SDiap32_Maestro.bin and DuetMaestroIAP.bin in the sys folder. I'm unable to ping the board at all now.
            Can you try doing a Bossa flash to 3.4 over USB?
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
            • iaTa
              Having never done this before, how do I erase the firmware on a Maestro - using a jumper or is there a button?
              Also is this my only option at this point as opening my printed housing to access the board is a real pita.
                If you're unable to reach DWC over the network then USB is your only option.
                You could use a serial terminal application like YAT to see if it will respond to commands line M115, otherwise reflashing the firmware directly is your only way forward.
                Yes the Maestro has a firmware erase jumper
                • iaTa
                  iaTa @iaTa last edited by iaTa
                  YAT is working via USB:
                  HTTP is enabled on port 80<LF>FTP is disabled<LF>TELNET is disabled<LF>Warning: the height map was loaded when the current Z=0 datum was not determined by probing. This may result in a height offset.<LF>Warning: Heater 0 predicted maximum temperature at full power is 182°C<LF>Warning: Heater 1 predicted maximum temperature at full p
                  M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2022-03-15 18:58:04<LF>ok<LF>
                    Ok, so it's at least got the firmware on it. That's a good sign.
                    Can you put the SD card in your PC and check the files there?
                    Replace the files in the www folder with the ones from the 3.4 DWC zip file.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.0/DuetWebControl-SD.zip
                    • iaTa
                      Yep tried that, still no network connection.
                      This is my config.g:
                      M550 P"Ender 3 Pro"                                ; set printer name
                      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                      M569 P0 S1                                         ; physical drive 0 goes forwards
                      M569 P1 S1                                         ; physical drive 1 goes forwards
                      M569 P2 S0                                         ; physical drive 2 goes backwards
                      M569 P3 S0                                         ; physical drive 3 goes backwards
                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                      M92 X80.00 Y80.00 Z400.00 E405.00                  ; set steps per mm
                      M350 X32 Y32 E128 I1					           ; set steps per mm for the extruder to x128 and X and Y to x32
                      M566 X800.00 Y800.00 Z60.00 E3000.00               ; set maximum instantaneous speed changes (mm/min)
                      M203 X12000.00 Y12000.00 Z900.00 E6000.00          ; set maximum speeds (mm/min)
                      M201 X6000.00 Y6000.00 Z200.00 E5000.00            ; set accelerations (mm/s^2)
                      M204 P600 T2000                                    ; set accelerations (mm/s^2) for print and travel moves
                      M906 X750 Y750 Z750 E900 I50                       ; set motor currents (mA) and motor idle factor in per cent
                      M208 X0 Y0 Z-0.5 S1                                ; set axis minima
                      M208 X235 Y235 Z228 S0                             ; set axis maxima
                      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                      M558 C"^zprobe.in" P9 H3 F150 T8000                ; Set Z probe type to bltouch and the dive height + speeds
                      M950 S0 C"zprobe.mod"                              ; Servo/gpio 0 is Z probe MOD pin
                      G31 P500 X-50 Y-16 Z2.65                           ; Set Z probe trigger value, offset and trigger height
                      M557 X15:200 Y15:200 S20                           ; define mesh grid
                      G29 S1                                             ; Load height map
                      M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 R2200 ; configure sensor 0 as thermistor on pin bedtemp
                      M950 H0 C"bedheat" Q100 T0                         ; create bed heater output on bedheat and map it to sensor 0
                      M143 H0 S80                                        ; set temperature limit for heater 0 to 80C
                      ;M307 H0 B0 S1.00                                  ; disable bang-bang mode for the bed heater and set PWM limit
                      M307 H0 A157.0 C482.1 D1.5 S1.00 V24.0 B0          ; disable bang-bang mode for the bed heater and set PWM limit (values copied from auto tune - M303 H0 S60)
                      M308 S1 P"e0temp" Y"thermistor" T98801 B4185 R2200 ; configure sensor 1 as thermistor on pin e0temp
                      M143 H1 S250                                       ; set temperature limit for heater 1 to 250C
                      ;M307 H1 B0 S1.00                                  ; disable bang-bang mode for heater and set PWM limit
                      M307 H1 A393.1 C130.5 D3.6 S1.00 V24.2 B0          ; disable bang-bang mode for heater and set PWM limit (values copied from auto tune - M303 H1 S210)
                      M950 F0 C"fan0" Q140                               ; create fan 0 on pin fan0 and set its frequency
                      M106 P0 C"Part" S0.4 H1 T195                       ; set fan 0 name and value. Thermostatic control is turned on
                      M950 F1 C"fan1" Q100                               ; create fan 1 on pin fan1 and set its frequency
                      M106 P1 C"Hotend" S1 H1 T45                        ; set fan 1 name and value. Thermostatic control is turned on
                      M950 F2 C"fan2" Q600                               ; create fan 2 on pin fan2 and set its frequency
                      M106 P2 C"LEDs" S0.1 H-1                           ; set fan 2 name and value. Thermostatic control is turned off
                      M563 P0 S"Hotend" D0 H1 F0                         ; define tool 0
                      M563 F2                                            ; Define LEDs tool
                      ; Pressure Advance
                      M572 D0 S0.30
                      ; Custom settings
                      M501                                               ; load saved parameters from non-volatile memory
                      T0                                                 ; select first tool
                      ; BLTouch startup
                      G4 S2							                   ; Pause a couple seconds
                      M280 P0 S160						               ; Clear any alarms
                      M402							                   ; retract pin just in case
                        With USB terminal connected and the ethernet cable connected, send M552, what does it reply with?
                        If it returns with an IP address, can you try pinging that IP from your PC?
                        Do the lights on the ethernet port light up with activity at all?
                        Do the lights on the switch/router port it's connected to light up?
                        • iaTa
                          M552
                          Network is enabled, configured IP address: 0.0.0.0, actual IP address: 192.168.1.15
                          No response from ping and all lights I would expect are on or flashing with activity.
                          I'll try Fallback procedure #1 from the link you provided and reflash 3.4 or go back to 3.3.
                            Phaedrux Moderator @iaTa last edited by Phaedrux
                            @iata said in Maestro issue updating from 3.3 to 3.4:
                            192.168.1.15
                            And this is the IP you're pinging?
                            And you're using http://192.168.1.15 to reach it?
                            I wouldn't try messing with the firmware just yet, as it appears to be working, but there should be no harm in trying. Remember to swap out for the DWC files for the firmware version you choose.
