Printer stuck in Probing Loop
Using Duet Controllers
  • undefined
    sunToxx
    I was printing small test objects for a filament chamber i am building and suddenly my printer gets stuck in a probing loop. It always probes the bed before print and so far all worked fine. And now I am suddenly getting this for no apparent reason
    16.3.2022, 23:15:43 Cancelled printing file 0:/gcodes/fila chamber triangle test_0.1mm_PLA_MK3S_1h7m.gcode, print time was 0h 2m
    !!! ABORTED !!! Failed to achieve < 0.01 deviation. Current deviation is 0.032mm.
    16.3.2022, 23:14:08 Error: Z probe readings not consistent
    16.3.2022, 23:13:30 Leadscrew adjustments made: -0.237 -0.361, points used 2, (mean, deviation) before (-0.303, 0.039) after (-0.000, 0.000)
    16.3.2022, 23:13:04 Leadscrew adjustments made: -0.286 -0.136, points used 2, (mean, deviation) before (-0.207, 0.047) after (-0.000, 0.000)
    16.3.2022, 23:12:46 M32 "0:/gcodes/fila chamber triangle test_0.1mm_PLA_MK3S_1h7m.gcode"
    File 0:/gcodes/fila chamber triangle test_0.1mm_PLA_MK3S_1h7m.gcode selected for printing
    16.3.2022, 23:22:44 Cancelled printing file 0:/gcodes/calib first layer 0_0.1mm_PLA_MK3S_5m.gcode, print time was 0h 3m
    !!! ABORTED !!! Failed to achieve < 0.01 deviation. Current deviation is 0.014mm.
    16.3.2022, 23:21:09 Leadscrew adjustments made: -0.276 -0.323, points used 2, (mean, deviation) before (-0.301, 0.014) after (-0.000, 0.000)
    16.3.2022, 23:20:39 Leadscrew adjustments made: -0.268 -0.203, points used 2, (mean, deviation) before (-0.234, 0.020) after (0.000, 0.000)
    16.3.2022, 23:20:09 Leadscrew adjustments made: -0.258 -0.372, points used 2, (mean, deviation) before (-0.318, 0.036) after (-0.000, 0.000)
    16.3.2022, 23:19:43 M32 "0:/gcodes/calib first layer 0_0.1mm_PLA_MK3S_5m.gcode"
    File 0:/gcodes/calib first layer 0_0.1mm_PLA_MK3S_5m.gcode selected for printing
    Any idea what is going on? It is a CaribouDuet which came assembled and calibrated and so far all was fine.
    undefined 1 Reply Last reply 16 Mar 2022, 23:17 Reply Quote 0
    • undefined
      fcwilt @sunToxx
      @suntoxx
      Please copy-and-paste your bed.g file using the </> tag.
      Thanks.
      undefined 1 Reply Last reply 16 Mar 2022, 23:53 Reply Quote 0
      • undefined
        sunToxx @fcwilt
        @fcwilt thanks for the response! It seems the print that failed before the problem appeared, left a small blob of filament on the tip of the nozzle and that interfered with the BLToch, because the BLTouch had moved up a tiny bit.
        1 out of 3
