    Can't show the camera in Print Status screen
    Duet Web Control
    • amimafeundefined
      amimafe
      Hi everybody,
      How can I display the camera in the print status screen?
      I can only see it in the Webcam section.
      I'm usin ESP32-CAM.
      Thanks!!
      MintyTreborundefined 1 Reply Last reply Reply Quote 0
      • MintyTreborundefined
        MintyTrebor @amimafe
        @amimafe You can't in standard DWC.
        However - you can put together your own status page, including webcam panels using the BtnCmd DWC plugin - eg:
        NodeDSF - Native Node-Red integration with Duet boards.
        BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
        ReleaseMgr - Duet update info inside DWC.
        Repo
        amimafeundefined 2 Replies Last reply Reply Quote 3
        • amimafeundefined
          amimafe @MintyTrebor
          @mintytrebor thank you for your answer. I will try to install this pluggin tomorrow.
          • amimafeundefined
            Hi again @mintytrebor ,
            I have installed BtnCmd and it works very well.
            I have a question, how can I change the size of the panel to add more options?
            Can I hide the menu that comes by default with DWC at the top?
            Thanks!
              @amimafe said in Can't show the camera in Print Status screen:
              In the plugins Global Settings
              The size of the screen is set by DWC/Browser resolution. You can however add as many tabs/pages as you like .
              It might be worthwhile reviewing the Wiki for the plugin.
              Repo
