    How to set the percentage complete in Gcode?
    Duet Web Control
    • moosi
      moosi last edited by
      I would like to set the percentage via Gcode. I know M73 but according to the wiki it is not supported by RRF.
      I could live with either the percentage or remaining time, but I have to set in the code.
      Are there any ways of doing this?
      thanks for your help
        dc42 administrators @moosi last edited by
        @moosi RRF supports the remaining print time function of M73. See https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m73-set-remaining-print-time.
        moosi 1 Reply Last reply Reply Quote 0
        • moosi
          moosi @dc42 last edited by
          thanks a lot for your reply.
          Yes it does support time, but DWC is only showing percentage. M73 has apparently no impact on DWCs calculations. AFAIK it uses filament and byte positions as fallback but no M73.
          Do I miss something?
            @moosi which firmware and DWC version are you using?
            Recent firmware and DWC versions show three different time estimates, of which one is "slicer". That is the one affected by M73.
            • moosi
              It´s:
              Board: Duet 3 MB6HC (MB6HC)
              DSF Version: 3.4-rc1
              Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.0rc1 (2022-02-09)
              I´m going to check the "slicer" time.
                @moosi also I suggest you upgrade to 3.4.0 stable.
                • moosi
                  thanks a lot. I will do so.
