    access duet web control trought VPN
    Duet Web Control
    • 0__Felky__0undefined
      0__Felky__0
      I recently buy a 3d printer with a Duet 3 Mini 5+ built in board and i wonder if is a way to have access the web control through VPN.
      Currently the web control only works if you log in from within my network, it cannot be reached from ouside. I have other things such as printers, NAS that works proprly.
      Thanks for help.
      CabalSoulundefined 1 Reply Last reply Reply Quote 0
      • CabalSoulundefined
        CabalSoul @0__Felky__0
        @0__felky__0 ofc, it works well via vpn and it is reasonable secure this way.
        Anycubic Predator, Orbiter Extruder , Duet Wifi, Mosquito Hotend, Remote Extruder Stepper cooling and Part cooling
        • Lo-Fiundefined
          Lo-Fi
          I think you'd need to configure the netmask using M553 and the gateway using M554.
          Add these after your M552:
          M553 P255.255.255.0
          M554 P192.168.1.1 ;(if that's your router address. Commonly also 1.254)
            CabalSoul @Lo-Fi
            @lo-fi my printer has a static up assigned.
            I just connect to my vpn and put the local ip of my printer in the browser no additional configurations necessary.
            Lo-Fiundefined 1 Reply Last reply Reply Quote 0
            • Lo-Fiundefined
              Lo-Fi @CabalSoul
              @cabalsoul Yeah, sometimes it will, just not in every circumstance and will also depend on the VPN type, configuration and router. Seemed a good place to start. Having said that, I'm assuming there that OP is using their router as VPN endpoint, not some other device on their network!
              0__Felky__0undefined CabalSoulundefined 2 Replies Last reply Reply Quote 0
                0__Felky__0 @Lo-Fi
                @lo-fi Hi, thank you so much for your help.
                @lo-fi said in access duet web control trought VPN:
                This is correct, i will try and let you know.
                  CabalSoul @Lo-Fi
                  @lo-fi my vpn endpoint is my synology NAS maybe that’s why it just works 🙂
