    execute Stop fan when temperature is lower than 45
    Gcode meta commands
    • adistr
      adistr last edited by
      Can I include this condition in my g-code file - "Stop fan command (M107) when the temperature is lower than 45 degrees"?
      Thanks,
      Adi
      • demonlibra
        demonlibra last edited by demonlibra
        M308 S1 P"temp1" Y"thermistor" A"HotEnd" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
        M950 F1 C"out5" Q50                          ; create fan 1 on pin out5 and set its frequency
        M106 P1 C"HOTEND" S1.0 H1 T50                ; set fan 1 value. Thermostatic control is turned on
        H1 - Enable thermostatic mode and select sensor monitored. Relates to the sensor number(s) created by M308.
        T50 - Set thermostatic mode trigger temperature 50C.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m106-fan-on
