    Duet 2 Wifi E0temp 2000
    Using Duet Controllers
    • RobiiinXundefined
      RobiiinX
      Hello, now im fix the bed temperature with the command:
      M305 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; CONFIGURE SENSOR 0 AS THERMISTOR ON PIN BEDTEMP
      Now i want to know the command that i can fix the e0temp. E0Temp still on 2000 dagrees.
      • RobiiinXundefined
        RobiiinX
        This is my config.g
        M305 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; CONFIGURE SENSOR 0 AS THERMISTOR ON PIN BEDTEMP ; configure sensor 0 as thermistor on pin bedtemp
        M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
        • blt3dpundefined
          blt3dp
          The config says you're using Extruder 1 Thermistor pin, but the comments say Extruder 0. I'd switch either the config or the physical spot it's plugged in and see if that helps.
          My 3D Printing YouTube Channel
          Better Living Through 3D Printing
          Follow me on Instagram and Twitter
          Instagram
          Twitter
            Photo of the actual wiring?
            2000c means it's not connected. Usually that ends up being the case either through connection error or wire break.
