    Homing issue with Dual endstop
    CNC
    • YYCSparks
      YYCSparks last edited by
      Hey guys,
      I have a Dual end stop setup for my MPCNC and I think I have my config setup right to have the system auto square but I have an issue specifically on my X axis when it homes that sometimes one of the X rails does not travel all the way to the limit switch and the motor stalls.
      My understanding and perhaps its wrong is that both of X motors should drive to the end stops and both stop once they reach the end stop.
      Here is my config and a video of what happens:
      Video:
      https://youtu.be/F8xYpFpeYBk
      Config:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Mar 24 2022 08:01:33 GMT-0600 (Mountain Daylight Time)
      M453                                            ; Set CNC Mode
      M550 P"MPCNC01"                                 ; set printer name
      G90                                             ; send absolute coordinates...
      G21												; Set units to mm
      M552 S1                                         ; enable network
      M586 P0 S1                                      ; enable HTTP
      M586 P1 S0                                      ; disable FTP
      M586 P2 S1                                      ; enable Telnet
      ; Configure Drives
      M669 K0                                         ; explicitly set Cartesian kinematics, even if I should not need to
      M569 P0.0 S1                                    ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                    ; physical drive 0.1 goes forwards
      M569 P0.2 S1                                    ; physical drive 0.2 goes forwards
      M569 P0.3 S0                                    ; physical drive 0.3 goes forwards
      M569 P0.4 S0                                    ; physical drive 0.4 goes forwards
      M584 X0.0:0.1 Y0.2:0.3 Z0.4                     ; set drive mapping, dual X axis and dual Y axis
      ; Configure Axis
      M92 X100.00 Y100.00 Z400.00				        ; set steps per mm
      M350 X16 Y16 Z16 I1                             ; configure microstepping with interpolation
      M566 X900.00 Y900.00 Z60.00				        ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 					; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00					    ; set accelerations (mm/s^2)
      M906 X900 Y900 Z900 I70							; set motor currents (mA) and motor idle factor in per cent
      M84 S240                                        ; Set idle timeout
      ; Configure Axis Limits
      M208 X0 Y0 Z-92 S1								; set axis minima
      M208 X636 Y501 Z92 S0							; set axis maxima
      ; Configure Endstops
      M574 X1 S1 P"io5.in+io6.in"						; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in and io6.in on X axis
      M574 Y1 S1 P"io3.in+io4.in"						; configure switch-type (e.g. microswitch) endstop for low end on X via pin io3.in and io4.in on Y axis
      M574 Z2 S1 P"io2.in"
      ; Configure Z-Probe
      ;M558 K1 P8 C"!io1.in" H5 F100 T3000 			; XYZ Workpeice probe connected to io1 input
      M558 P5 C"!^io1.in" H5 F200:75 T6000            ; set Z probe type to switch and the dive height + speeds
      G31 P850 X0 Y0 Z14.5                             ; set Z probe trigger value, offset and trigger height
      ; Configure Heaters
      M140 H-1										; Disable heated bed
      M564 S1 H1 										; Disable jog commands when not homed
      M308 S2 Y"drivers" A"DRIVERS"              		; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
      M308 S3 Y"mcu-temp" A"MCU"                      ; configure sensor 3 as thermistor on pin e1temp for left stepper
      ; Configure Fans
      ; Configure Tools
      M950 R0 C"out6" L10000							; Spindle 0 uses exp.heater1 as RPM pin and has a max RPM of 10000
      M563 P0 S"Spindle 1" R0                         ; Define the router as tool 0
      ; Custom settings
      ;M575 P1 S1 B57600                              ; Enable PanelDUE
      M911 S21.0 R23 P"G91 G1 Z3 F1000" 				; Configure power loss resume
      M501											; Load Stored Parameters
      G54                                             ; Select Workspace Coordinate 1
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @YYCSparks last edited by
        @yycsparks
        Is something preventing movement all the way to the end stop before the endstop is triggered?
        There was a thump suggesting that.
        YYCSparks 1 Reply Last reply Reply Quote 0
        • YYCSparks
          YYCSparks @fcwilt last edited by
          @fcwilt hey thanks for the reply, so based on your thoughts you think its more mechanical than software based? I will go back over the rails tonight and see what I can find.
          • fcwilt
            @yycsparks
            I have a printer with dual Y steppers and dual Y endstops.
            That same printer has triple Z steppers with triple Z endstops.
            They all home smoothly with no "thumps".
            Here is a quick-and-dirty video. I have purposely put the bed way out of level to demonstrate auto bed leveling.
            Homing video
            • YYCSparks
              @fcwilt said in Homing issue with Dual endstop:
              Thank you for sharing the video that is really slick, and my config should result in the same result I assume?
              I will check that the rails will allow for the required movement.
              On a side note what printer is that?
              • fcwilt
                @yycsparks said in Homing issue with Dual endstop:
                Well if your printer has two Y steppers and three Z steppers you should see much that same.
                Something I designed myself. I was reading about different types of printers and was intrigued with the "MarkForged" kinematics. So I set out to build one. I also chose to try belt drive for the Z axis - very pleased with the result.
