    RepRap Mock server
    Duet Web Control
    232
    • AndMaz
      AndMaz last edited by
      Hi
      I want to develop a HTTP client (using this spec: https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests) and I was wondering if there's a mock server that I can use during the development?
      This would greatly ease the dev process and would help me to test my client during the high load. The latter part is specially important because in production it should be able to handle thousands of devices at the same time
      chrishamm 1 Reply Last reply Reply Quote 0
      • chrishamm
        chrishamm administrators @AndMaz last edited by
        @andmaz Not yet. In SBC mode we'll provide support for rr_ HTTP requests in v3.5 but until then you must use the Duet's HTTP server.
        Duet software engineer
        AndMaz 2 Replies Last reply Reply Quote 0
        • AndMaz
          AndMaz @chrishamm last edited by
          @chrishamm thank you for quick reply 👍
          (wishful thinking) Would be awesome to have a simple http server (could be express.js or something else) just producing some fake data while mimicking RepRap's behaviour.
          Anyway, keep up the good work 😃
          • AndMaz
            Hi @chrishamm sorry for pinging you but can you explain the rationale behind the seqs.reply value?
            The docs (https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation) are not very clear about it. The only reference that I found was:
            There is an extra value seqs.reply as well which is used notify clients about new messages (see rr_reply).
            My question is: How does the seq.reply increase?
            I'll try to explain what I mean.
            For example, this request /rr_gcode?gcode=M120%0AG91%0AG1%20X-10%20F6000%0AM121 , which results in the following response
            Error: G0/G1: insufficient axes homed
            increases the seq.reply by 4. Why 4?
            On the other hand, this /rr_gcode?gcode=M106%20P1%20S0.16 request, with an empty response, increases the seq.reply by 1. Why 1?
            What's the difference? How the reply counter is increasing?
            The ultimate goal for me is to understand how can I relate a /rr_gcode req. with a /rr_reply response.
            The /rr_gcode does not provide any info for this so I'm guessing that the seq.reply is the answer for this.
              dc42 administrators @AndMaz last edited by
              @andmaz said in RepRap Mock server:
              It's probably causing 3 blank lines to be returned as well as the one containing the error message.
              Because it is returning a single blank response line.
              The only guarantee is that seq.reply will increment by at least one every time a new reply is generated.
              AndMaz 1 Reply Last reply Reply Quote 0
              • AndMaz
                AndMaz @dc42 last edited by
                @dc42 thank you for your response.
                Can you explain the reason for the blank lines? In what situations it returns blank lines? Can it return more that 3 blank lines?
                Overall, current API makes difficult to relate the req. to /rr_gcode and response from /rr_reply.
                It would be cool if /rr_gcode response could include the seq number (e.g., { "buff": 226, "seq": 12345 }) and the /rr_reply could include the seq in response string. This way relating req and res would be much easier.
                  DWC manages it. What I think it does is to send the command via rr_gcode and then wait for the sequence number to increase, indicating that a response has been received.
                  AndMaz 1 Reply Last reply Reply Quote 1
                  • AndMaz
                    AndMaz @dc42 last edited by AndMaz
                    @dc42 yeah, I've been looking at DWC and the logic that's implemented there. However, I still continue to think that /rr_reply response is not consistent and could be improved (or at least documented in detail).
                    In any case, thank you for your help 👍
