Strange Z error
So yesterday I changed my nozzle for the first time. I do not know the exact steps I took. I might have turned the CaribouDuet off while changing it. I think I did. I made sure the nozzle is the same size and as I already had the old nozzle off two times, in order to get rid of filament stuck in the extruder somewhere, I was not too worried.
However, the next print scratched the sheet and I stopped it with Emergeny Stop. However, the strange part about this is, that after the emergency stop, which restarts the printer, the Z offset is perfectly fine again. That means, I am still printing now, with the same Z height as before. So the same Z height as before the nozzle change. The same z hight as during scratching.
G31 K0 P500 X31.6 Y-10.1 Z2.75 is the setting in config.override (caribou handles Z via save babystep makros and config.override) and G31 Z2.75 is what I entered into a print sheet macro after leveling. So there is no room for a mistake, it still is the same z height. Still, it scratched the sheet.
Can anyone list some factors that could have led to this? I dont want it to happen again and scratch the other side. And what exact steps should I have taken after a nozzle change?
I did cancel a print before it happened, because i forgot to add plastic repellant paint to the new nozzle and I think i saw a message in the console, something like "already done that" about measuring. I didnt think much of it, I guess I should have?
@suntoxx said in Strange Z error:
Unless something was bent during the crash.
Remeasure the z offset for the probe since after changing the nozzle the distance between probe trigger height and nozzle tip is likely slightly different.
@phaedrux said in Strange Z error:
Thanks for the reply.
What could have been bent? I started the print, he kind of engraved the 5cm line into the print bed, I hit the Emergency Stop button. Then he restarted. I started with a big babystep offset and printed a single layer, lowering it slowly and end up at 0 offset. So the offset definitely remained unchanged. Plus it was still high enough, to print normally. I did end up raising it by 0.04 now, but just to optimize the imprint of the structural sheet. You think something could have been bent in the process?
How exactly would i do this? I want to change nozzles quite often, so it should be as hassle free as possible.
@phaedrux and what could have caused this? I did interrupt or pause a print, to apply some plastic repellant paint, after the nozzle change. I might have moved it on the z axis unintentionally? Quite unsettling not to know which factors could have led to this.
I believe Caribou has a method for this do they not? I'm not super familiar with their config set, but from what I've seen it's quite involved.
@phaedrux I am not quite sure what exactly you mean. The whole calibration process for the BLTouch? 3mm distance etc? Or just start with a bit higher Z offset and work down (which is done via babysteps and saved in config.override)?
The former would make nozzle changes quite a hazzle, even with an LGX.
I don't know what to tell you about that. Here is how we recommend you do it: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
I'm not sure what your Caribou config setup recommends.
@phaedrux you dont go through all of that when you change your nozzle, do you? What steps do you personally do then, or do you rarely change it?
Well yes actually. If I change the nozzle and I want an accurate first layer I need to at the very least re-measure the nozzle tip to probe trigger height offset (G31 Z)
This part in particular: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
It's not really a time consuming process. I even have a macro to make it repeatable.
M291 P"Grid bed compensation map and Z Probe trigger height will be cleared. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel. M291 P"Heights will be found in gcode console if logging successful gcode is enabled" R"Did you remember to enabled gcode logging?" S3 ; Clear compensation map and Z probe trigger height ; G28 ; home all axis M561 ; Disable any current bed compensation G90 ; Absolute positioning T0 ; Activate first tool M98 P"ZSpeedsSlow.g" ; Set lower speeds for Z homing and lower Z motor current M913 Z50 ; Drop motor current to prevent damage in case of head crash ; Preheat to probing temps ; M291 P"Preheating to bed to 60 and nozzle to 210 for accurate probing" M104 S210 ; Set nozzle to 210 and release M190 S60 ; Set bed to 60 and wait M109 S210 ; Set nozzle to 210 and wait M98 P"0:/macros/musical tunes/GetAttention.g" ; 1 ; M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3 M98 P"0:/macros/Calibration/Bed Leveling/1_Center Nozzle on Bed" G90 G1 Z3 F400 M400 G92 Z4 ; Reset z to 8 to allow jogging up to touch bed to nozzle M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3 M400 G92 Z0 ; Set z = 0 G90 G1 Z3 F400 M104 S0 ; Turn off hotend heater as it's no longer needed M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" T3 M400 M98 P"0:/macros/Calibration/Bed Leveling/1_Center Probe on Bed" G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-3 ; measure probe height and set it. M400 M500 P31 ; save trigger height to config-override.g G1 Z5 M98 P"0:/macros/musical tunes/GetAttention.g" ; Turn off heaters ; M104 S0 ; Set nozzle to 0 and release M140 S0 ; Set bed to 0 and release M98 P"ZSpeedsNormal.g" ; return to normal speeds M98 P"CurrentsNormal.g" M400 M291 P"Homing" G28 ; Home Z M84 ; turn off the motors M291 P"Probing complete. Turning off heaters and homing axis. Check log for trigger heights and enter into config.g" S2
I have limited experience with the caribou config files and macros, but I believe they have something similar.
@phaedrux I checked the macro folders and did not see anything like the one you posted.
"Jog" nozzle means to use the babysteps command on the display?
So it triggers 10 times and you watch it to see if the values are consistent and then it automatically saves the new 0 height value.
Do I understand this correctly, you reduce motor speed and also reduce motor current, which makes the motor too weak to damage the print sheet?
Yes you got it. Obviously you don't have the same sub macros as I do, but you get the idea of the function and would have to modify for your specifics.
At the most basic level though you can follow the instructions in that earlier link for measuring the offset within 5 minutes.
It seems we dont have anything like it and the suggestion in the group didnt even include deactivating the mesh compensation. I definitely want to create a macro similar to yours, that seems much better to me.
In the quoted code, it looks like a window will pop up and you are supposed to jog the nozzle and then press OK. How do you jog the nozzle while the window is open and watch the nozzle touch the bed? Does that need dwc and the printer screen at the same time?
And do you first center the nozzle and then the probe onto the same spot, to eliminate possible deviations? Does it automatically use the currently saved probe xy offset?
Also, I am not sure if I have done it sufficiently correct before as the instructions involve G92 Z0 and G30 S-1. On caribou we simply save the current babysteps with a macro and it gets saved into config-override. So all I did after the nozzle change is, go down with the nozzle with 0.01mm babysteps till it touches the bed and then hit the save babysteps macro, which resulted in G31 K0 P500 X31.6 Y-10.1 Z2.76 in the config-override.g. Was that a wrong or dangerous thing to do? Seems to work so far.
Thats the babysteps macro
if state.status != "processing" ; printer is not currently printing! if move.axes[2].babystep !=0 ; if no babysteps are currently adjusted - exit routine M291 R{"z-Trigger Height"} P{"Current: " ^ sensors.probes[0].triggerHeight ^ ", Babysteps:" ^ move.axes[2].babystep ^ ", New: " ^ sensors.probes[0].triggerHeight - move.axes[2].babystep} S2 M291 P{"Press OK to continue or CANCEL to abort."} R{"Setting z-probe offset to " ^ sensors.probes[0].triggerHeight - move.axes[2].babystep ^ "?"} S3 M400 ; finish all current moves / clear the buffer G31 Z{sensors.probes[0].triggerHeight - move.axes[2].babystep} ; set G31 Z offset to corrected M500 P10:31 ; save settings to config-overide.g - G31 P31 saves trigger height M290 R0 S0 ; set babystep to 0mm absolute G28 else M291 P"Babysteps are 0.000. z-trigger height will not be changed." S1 else M291 S2 P"z-Trigger height cannot be changed during an ongoing print. Please run this macro when the print is finished, and the bed is clear and ready!" R"WARNING!" ;
M291 ill pop up a dialog box with Z movement buttons on the DWC and Paneldue.
That's up to you. In my example it moves the nozzle to the center where Z0 is set, and then it moves the probe over to that exact spot. It's not strictly needed though.
I have no idea about any of that unfortunately. I have seen that baby steps macro posted before and I think that's what I thought might be applicable to your case, but I have not used it. It seems to do something similar, but you'd have to ask the author of it.
@phaedrux thanks for your help. I am working on adapting your macro for myself, I hope that is ok. This is where I am currently at.
M291 P"Grid bed compensation map and Z Probe trigger height will be cleared. Ok or Cancel?" R"WARNING" S3 ; User must click OK or cancel. G28 ; home all axis M561 ; Disable any current bed compensation G90 ; Absolute positioning T0 ; Activate first tool M203 Z500.00 ; Set lower speeds for Z homing and lower Z motor current M913 Z50 ; Drop motor current to 50mAh to prevent damage in case of head crash M291 P"Preheating to bed to 60 and nozzle to 210 for accurate probing" M104 S210 ; Set nozzle to 210 and release M190 S60 ; Set bed to 60 and wait M109 S210 ; Set nozzle to 210 and wait M98 P"0:/sys/playsound.g" M291 P"Nozzle will now move to center of bed to reset Z0 and calibrate probe" S3 xxxM98 P"0:/macros/Calibration/Bed Leveling/1_Center Nozzle on Bed" ;TODO<-------------<Manual G1 move? G90 G1 Z3 F400 ;Moves Z a bit up? M400 G92 Z4 ; Reset z to 8? to allow jogging up to touch bed to nozzle ;feeds arbitrary coordinate? M291 P"Jog the Z Axis until the bed and nozzle are touching and click OK" R"Setting Z=0" Z1 S3 M400 G92 Z0 ; Set z = 0 G90 G1 Z3 F400 M104 S0 ; Turn off hotend heater as it's no longer needed M291 P"Probe will now move to center of bed and measure trigger height 10 times" R"ZProbe Trigger Height Calibration" T3 M400 xxxM98 P"0:/macros/Calibration/Bed Leveling/1_Center Probe on Bed" ;TODO<--------------<Manual g1 move? G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-1 M400 G1 Z5 M400 G30 S-3 ; measure probe height and set it. M400 M500 P31 ; save trigger height to config-override.g ;need save babysteps macro anyway? G1 Z5 M98 P"0:/sys/playsound.g" M104 S0 ; Set nozzle to 0 and release M140 S0 ; Set bed to 0 and release M203 Z1000.00 ; return to normal speeds (better to revert to saved values than to set them manually?) M906 X1250 Y1250 Z650 ;return to normal currents M400 M291 P"Homing" G28 ; Home Z M84 ; turn off the motors M291 P"Probing complete. Turning off heaters and homing axis. Check log for trigger heights and execute Save Babysteps Macro" S2
There are some points I wonder about though. You use another macro to return the z motors to your previous mAh. Is there a reason behind it, like does that macro get automatically updated after a firmware update that might mess with the values, or what is the idea behind it?
Then the move to the center with nozzle and probe. Is there an elegant way to get the probe to that position? Like do you use a relative movement reflecting your xy offset after the nozzle was centered, maybe even by reading out that value instead of manually copying it? Or you simply calculate the center?
I do that so that there is only one place I have to change the values if I want to make adjustments and it will then reflect in all the other macros that call it. Make shift variable from before there were actual variables.
Again the reason for the macro for this is that I can adjust it as needed incase the actual probe gets moved and I need to change the offset. I can just update the position in that one macro. But to be honest it doesn't matter so much if I set the Z0 at the nozzle position and then do the probe testing 1mm away from that spot. General vicinity is enough.
You can see the entire macro set here: https://github.com/Duet3D/RRF-machine-config-files/tree/master/DBotCoreXY/x0r-wifi-RRF3
Does that mean that now it would be possible to save the current state from within the macro, change it to a lower value and at the end return to the saved state?
I want to do it the same way, because there is quite some distance between nozzle and probe on the caribou and the mesh compensation is not working as perfect as I would like. I assume there is no way to tell the head to make a relative movement based on the current g31 xy offset?
I will check that out, thanks!
That may be possible with conditional gcode, but my example is not that fancy.
With conditional gcode and the object model that is possible, though I don't know the exact syntax off the top of my head. But if you're hte programmatic type, see here: https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands
@phaedrux i had a look at the metacommands, but it seems with the current level of documentation, the time needed to get that working probably outmatches the work it would save me. I got the macro working though and quite consistently at that. I keep ending up with either 2.777 or 2.78 in console and on multiple runs of the macro I end up with either g31 Z2.77 or Z2.78 which seems fine to me. Do you end up at the exact same G31 Z if you run the macro multiple times in a row? Is it just practice, or is that deviation to be expected and can't really be avoided?
Edit: I did the "touch down" by looking the the nozzle and confirming the height when the shadow disappears. Is this the correct way, or is the speed and motor current reduced, in order so that i can move the extruder downwards until it stops moving?
Edit2: The mesh compensation is active again after the macro finishes? Should I restart Duet after the macro?
There's always going to be some small variation. 0.01mm is pretty tight. Nothing to worry about.
I use the same method. It helps to have a light source behind the printer so you can see the gap disappear. Maybe there's a better way, but it's good enough and works for me. It doesn't really matter so much because you're calibrating once and it stays set for a long time.
That depends on where you activate it in the first place. You can load it at the end of homeall, or at start of a print in start.g or in the slicer start gcode.
I got a number of nozzle sizes and print in a lot in varying layer heights. I want to take full advantage of how easy nozzle swapping is in the lgx, so as soon as my torque screwdriver arrives, I want to start using the optimal nozzle for each height. The macro sets me up very nicely for this!
I will check that out.
Thanks for the help!
Did you get an answer on how to center the probe without hardcoding?
This is my way:
G1 X{((move.axes[0].max + move.axes[0].min) / 2) - sensors.probes[0].offsets[0]}, Y{((move.axes[1].max + move.axes[1].min) / 2) - sensors.probes[0].offsets[1]}, F1800
@fcwilt You need to change "axis" to "axes".
@fcwilt Thanks, this looks good. From where do you get for example the "sensors.probes[0].offsets[0]"? Is there a list somewhere?
The DWC has a plug-in for browsing the object model:
If it is not started just start it and then you can browse through the object model.
Some of what I know is just from trial-and-error, other things were picked up here on the forum.
This post is deleted!
