    About M591 Set
    Filament Monitor
    duet3 6hc
    • huai3895undefined
      huai3895
      As this course ,i chonice P7 to sensing filament,i use a itr9608 made pcb to Detect rotation
      AB005D3BE70B8BDA51F8D3F38FDED473.jpg 72A9116204A9FA591D42EEE576A7A9FB.jpg 7D24EF067D69ECB9BF66F540AB7B8BD0.jpg
      However,when i connect it directly to duet3 ,It often works erratically.
      Why? so I think maybe it doesn't produce pure pulses with the same width
      I plan to use a singlechip to collect signal from itr9608,and send Pure pulse to duet3.
      Questions:
      1,Is my guess correct?
      2 ,if its correct ,what is the standard of pulse?
        dc42 administrators @huai3895
        @huai3895 the issue people have had before with pulse-detecting optical filament sensors is that there isn't a clean transition at the start and end of each pulse. The solution is to use a Schmitt trigger or a comparator with positive feedback to process the output from the opto switch.
