    filament runout
    Filament Monitor
    • DallasH
      DallasH last edited by
      using a simple high switch on extruder stop e0. do i execute the M591 P1 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop or dp you put it in the config folder. or just send the commands from DWC?
        Depends on when you want it to take effect.
        Putting the command in config.g would be the easiest way.
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_filament#configuring-other-filament-out-sensors
