    Advise FOAM Cutter CNC machine
    CNC
    1
    1
    129
    • Vic 0undefined
      Vic 0
      Good morning
      Sorry and my classic English
      I would like to build a hot wire machine to cut independent 5 axis polystyrol
      2 X Motors
      2 Y motors
      1 Rotating Plate Z Motor
      I tried various hardware solutions but was very impressed by the simplicity of the Duet with Touch display
      The machine is very simple
      I would like to use 2 independent Y axis motors with 1200mm travel, 2 independent X axis motors with 2000mm travel and finally a Z axis motor
      Home and max area sensors For X-Y
      Hot wire temperature control controlled by 12 - 48 volt voltage variator
      My question is the following:
      What kind of Hardware Duet can I use both Main and Tauch panel?
      Which FW?
      Which experimental setup for the listed features?
      Thanks in advance for your advice
