btt smart filament sensor
btt sfs
After USING BTT smart consumable sensor, I found that pressure extrusion seems to affect the accuracy of smart filament sensor. After I disable M572, the filament can be detected normally, but after using M572, it will become abnormal. Is it possible that the filament extrusion lengths read by RRF for these two functions are different? The filament sensor does not subtract the length of the m572's pressure propulsion -
How do you have it configured? How is it installed? Is it similar to the Duet Magnetic Filament sensor?
