    DuetWifi and 5v two pin laser
    Laser Cutters
    1
    • asboundefined
      asbo
      I've put a DuetWifi in one of those tiny laser engravers made from old optical drive assemblies, like this: alt text
      Everything moves as it should, but I can't figure out how to control the laser. It runs on 5v and just has a positive and negative pin.
      I built the circuit shown in the wiki here, but with a 4001 IC instead since I had some already. It outputs 5v when it should, but doesn't turn the laser on as I don't think it can provide enough current.
      Can anyone help?
      asboundefined 1 Reply Last reply Reply Quote 0
      • asboundefined
        asbo @asbo
        The solution to this was to use a MOSFET. I salvaged one from an old motherboard, a 15N03H, which has a Gate Threshold Voltage of between 1 and 3 volts. Since the heater3 pin outputs 3.3v, I put a diode before the gate to drop it down to just below 3 volts.
        It's working, but I don't know if it's considered an acceptable solution. Does anyone with more knowledge have any insights?
        • asboundefined
          asbo @asbo
          Scratch that, it was working, but now the laser stays on when it shouldn't.
          I'm too tired to work out why at the moment though.
