    Probe centering macro: G60 or WCS?
    CNC
    1
    1
    202
    • sinned6915undefined
      sinned6915
      I was looking at DiaBase's probe centering macro and it utilizes G60 memory store/recall for positions. It also has some interesting commented out gcode variable calls which got me to thinking about what might be the best approach.
      Is there a difference in memory or processing speed using variables or stored memory?
      Its quite a novel approch and well documented- finding a coarse X center followed by fine Y and then fine X center.
      M291 P"Bed will now move. Is Probe inside cavity?" R"Crash Check" S3
      M561
      M574 X1 Y1 S2; configured to use Probe
      ; var local.probeTipRadius = 3 ; in mm
      M400
      G60 S1                                     ; Save start position to slot 1
      ; Probe in X direction ("coarse")
      M558 K0 F150
      G38.2 X{move.axes[0].userPosition + 6} P0 ; Adjust the + n amount to the travel limit (expected hole diameter is an upper bound)
      M400
      G60 S2                                     ; Save +X position to slot 2
      G0 X0 R1 F300                              ; Return X to start position (disengage the probe) (slot 1)
      G38.2 X{move.axes[0].userPosition - 6} P0 ; Ajust the - n amount to the travel limit
      G53 G0 X{move.axes[0].machinePosition + ((state.restorePoints[2].coords[0] - move.axes[0].machinePosition) / 2.0)} ; Move to pretty good X-value of hole center
      ; Probe in Y direction ("fine")
      G38.2 Y{move.axes[1].userPosition + 8} P0 ; Adjust the + n amount to the travel limit
      M400
      G60 S3                                     ; Save +Y position to slot 3
      G0 Y0 R1 F300                              ; Return Y to start position (disengage the probe) (slot 1)
      G38.2 Y{move.axes[1].userPosition - 8} P0 ; Adjust the - n amount to the travel limit
      ; M400
      ; var global.yHoleDiameter = {state.restorePoint[3].coords[1] - move.axes[1].userPosition + (2.0 * local.probeTipRadius)}
      G53 G0 Y{move.axes[1].machinePosition + ((state.restorePoints[3].coords[1] - move.axes[1].machinePosition) / 2.0)} F300; Move to very good Y-value of hole center
      M400
      G60 S1                                     ; Save "pretty good X" and "very good Y" position to slot 1
      M558 K0 F100
      ; Probe in X direction ("fine")
      G38.2 X{move.axes[0].userPosition + 8} P0 ; Adjust the + n amount to the travel limit
      M400
      G60 S4                                     ; Save +X position to slot 4
      G0 X0 R1 F300                              ; Return X to pretty good center position (disengage the probe) (slot 1)
      G38.2 X{move.axes[0].userPosition - 8} P0 ; Ajust the - n amount to the travel limit
      ; M400
      ; var global.xHoleDiameter = {state.restorePoint[4] - move.axes[0].userPosition + (2.0 * local.probeTipRadius)}
      ; var global.averageHoleDiameter = {(global.xHoleDiameter + global.yHoleDiameter) / 2.0}
      ; var global.diameterDifference = {global.xHoleDiameter - global.yHoleDiameter}
      G53 G0 X{move.axes[0].machinePosition + ((state.restorePoints[4].coords[0] - move.axes[0].machinePosition) / 2.0)} F300; Move to very good X-value of hole center
      M558 K0 F150
