Web server started but blank screen when I connect to the IP.
Updated with DuetWiFiServer. Panel shows the web server started and IP but blank screen in DWC when I connect to the IP. Please advise.
Can you send M122 via USB terminal and share the results here? We need to know what firmware version you are using and what version of DWC files are present on the SD card in the WWW folder.
What IP address are you trying to connect to? Are you sure that is the Duet IP?
Best to follow along with this: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
