Where do I find the files?
I need to install Version 2.05.1
DuetWiFiServer 1.23
DuetWebControl 2.0.7 or 1.22.6Where do I find the files? I see Changelogs etc but no files to install.
No I cannot update to 3 already f'ed up all trying that.
@empiricus said in Where do I find the files?:
DuetWiFiServer 1.23
Everything you need to know can be found here:
Down on the left, near the bottom, you should see the reference to RepRapFirmware
@fcwilt Thanks, I installed 2.05 and Duet wifi server but there is nothing on how to install Duet webControl. Zip contains folders and .gz files. server is starting but nothing shows up when connecting to the IP ( blank white window).
There should be a ZIP named DuetWebControl or something like that, with some numbers related to the version.
Just upload that as a "system" file.
The firmware should start unzipping it and putting all the files in place.
At some point you should get a prompt about applying the update.
@fcwilt Thanks all installed
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
