    DWC plugin uninstallation issue on Armbian SBC
    Plugins for DWC and DSF
    • Falcounetundefined
      Falcounet
      I'm having an issue while trying to uninstall a plugin from DWC on a SBC running Armbian (not a Raspberry Pi).
      I'm getting ArgumentException in UninstallPlugin: Failed to get file info (error 22).
      After some research, I noticed this happens from DSF version above 3.4-b7.
      After looking at the changes made since, I think the issue comes from this commit : https://github.com/Duet3D/DuetSoftwareFramework/commit/7739e916c8fb6595d4ae73fc5d1bac131edf5df6#diff-b494305c06eb76f8c94cc28110419e5b82dc18da06e884f0cee4a36b04f4ebf0
      As I understand, this commit add a check to prevent uninstallation of plugins like duetpimanagement.
      I would like to understand why the stat command from LinuxAPI and used by GetPermissions method fails.
      I tried enabling the trace log level but it doesn't give more useful info.
      The error message doesn't give any info on what file the stat command is applied (the pathname variable value).
      I could add these infos to the source myself but I don't have any clue how to build the binaries.
      Would it be possible to add the pathname variable value and the stat command result value in the exception message to help to track down the issue ?
      Any more clue about that issue ?
      0 chrishamm committed to Duet3D/DuetSoftwareFramework
      Version 3.4-rc1 candidate
      Added new ReadThumbnailContent field to GetFileInfo API call
      Added support for parsing the number of total layers (e.g. NUM_LAYERS 123)
      Made class libraries compatible to netstandard2.1
      Renamed ParsedFileInfo and ParsedThumbnail classes to GCodeFileInfo and ThumbnailInfo
      Updated object model, unit tests, and components
      Bug fix: Tool for custom HTTP endpoints did not replace query values when starting other programs
      Bug fix: Packaged plugins (like duetpimanagementplugin) could be uninstalled using DWC
      • noobydpundefined
        noobydp
        I also have this error (running on RPI 4 with dietpi image).
        I cannot uninstall the BtnCmd plugin, or a custom one I wrote.
        Falcounetundefined 1 Reply Last reply Reply Quote 0
          Falcounet @noobydp
          @noobydp Funnily I worked on this yesterday and I found both the cause and a fix.
          I still need to do some testing with the DuetPi image and I will post a PR on DSF.
          Can you post here the result of uname -a please ?
