    Passing variables to DSF-Python
    DSF Development
    • oozeBotundefined
      oozeBot
      Can @chrishamm or someone give me a few pointers on how to pass variables to DSF-Python using custom mCodes? I would have assumed it would be like MXXXX V{var.localVar} but DSF-Python reads parameter V as "var.localVar" instead of its value.
      Am I missing something simple? Or is there a better way? Thanks
      • oozeBotundefined oozeBot marked this topic as a question
      • chrishammundefined
        chrishamm administrators @oozeBot
        @oozebot You can use the EvaluateExpression command to get the value of expressions. In your case the parameter of MXXXX will have a string value and a property isString which is false meaning that you're dealing with an expression.
        I will consider (optional) automatic expression evaluation for the Flush command in v3.5. DSF uses that same mechanism internally, too.
        Duet software engineer
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @chrishamm
          @chrishamm Thanks - but am going to have to plead ignorant and ask for a touch more guidance as I can't find any examples or documentation other than what what auto-generated here: https://duet3d.github.io/DuetSoftwareFramework/api/DuetControlServer.Commands.EvaluateExpression.html
          Could you assist by expanding the following snippet on the Python side using EvaluateExpression to read the value of var.localVar? Thanks!
          gCode:
          var.localVar = "testing"
          M1234 V{var.localVar}
          Python
          cde = intercept_connection.receive_code()
            if cde.type == CodeType.MCode:
              if cde.majorNumber == 1234:
                tVar = ParseParam(cde.parameter("V"))
          Falcounetundefined 1 Reply Last reply Reply Quote 0
          • Falcounetundefined
            Falcounet @oozeBot
            @oozebot You can use the EvaluateExpression command from DSF in Python in that way :
            from dsf.connections import CommandConnection
            from dsf.commands.basecommands import evaluate_expression
            from dsf.commands.codechannel import CodeChannel
            def send_simple_command():
                command_connection = CommandConnection(debug=True)
                command_connection.connect()
                try:
                    expression = "{var.localVar}"
                    res = command_connection.perform_command(evaluate_expression(CodeChannel.HTTP, expression))
                    print(f"Evaluated expression: {res}")
                finally:
                    command_connection.close()
            if __name__ == "__main__":
            You can get the channel you are intercepting the Gcode from using cde.channel instead of CodeChannel.HTTP in the above example.
            oozeBotundefined 1 Reply Last reply Reply Quote 1
            • oozeBotundefined
              oozeBot @Falcounet
              @falcounet Thank you! This was just the nudge we needed. I was trying to import evaluateexpression, not evaluate_expression - doh!
              • oozeBotundefined oozeBot has marked this topic as solved
