    slow upload
    Duet Web Control
    • Adamfilipundefined
      Adamfilip
      Noticing very slow upload speeds. and getting disconnects ofen
      Recently (weeks ago) changed SD card and Speed test shows 2.2mbps
      If I restart the board, upload speeds is fine again around 500kbps.
      error log
      Z: none
      power up + 00:00:00 [warn] Error: in file macro line 105: M581: missing parameter 'T'
      power up + 00:00:00 [warn] Error: Accelerometer not found on specified port
      power up + 00:00:00 [info] G10 P0 X0 Y0 Z0
      power up + 00:00:00 [info] G10 P0 R0 S0
      power up + 00:00:00 [debug] Done!
      power up + 00:00:00 [debug] RepRapFirmware for Duet 2 WiFi/Ethernet is up and running.
      power up + 00:00:01 [warn] WiFi module started
      power up + 00:00:06 [warn] WiFi module is connected to access point Filipogeco, IP address 192.168.0.195
      power up + 00:00:07 [warn] HTTP client 192.168.0.40 login succeeded
      2022-09-04 20:43:39 [warn] Date and time set at power up + 00:00:07
      2022-09-04 20:43:39 [warn] HTTP client 192.168.0.207 login succeeded
      2022-09-04 20:45:03 [debug] === Diagnostics ===
      2022-09-04 20:45:03 [debug] RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2rc3+ (2022-08-31 12:50:46) running on Duet WiFi 1.02 or later + DueX5
      2022-09-04 20:45:03 [debug] Board ID: 08DLM-996RU-N85T0-6JKF2-3SJ6Q-1AVVR
      2022-09-04 20:45:03 [debug] Used output buffers: 1 of 26 (23 max)
      2022-09-04 20:45:03 [debug] === RTOS ===
      2022-09-04 20:45:03 [debug] Static ram: 23860
      2022-09-04 20:45:03 [debug] Dynamic ram: 75752 of which 40 recycled
      2022-09-04 20:45:03 [debug] Never used RAM 12356, free system stack 152 words
      2022-09-04 20:45:03 [debug] Tasks:
      2022-09-04 20:45:03 [debug]  NETWORK(ready,23.4%,211)
      2022-09-04 20:45:03 [debug]  HEAT(notifyWait,0.0%,333)
      2022-09-04 20:45:03 [debug]  Move(notifyWait,0.0%,304)
      2022-09-04 20:45:03 [debug]  DUEX(notifyWait,0.0%,24)
      2022-09-04 20:45:03 [debug]  MAIN(running,75.7%,446)
      2022-09-04 20:45:03 [debug]  IDLE(ready,0.9%,30)
      2022-09-04 20:45:03 [debug] , total 100.0%
      Owned mutexes:
      2022-09-04 20:45:03 [debug] === Platform ===
      2022-09-04 20:45:03 [debug] Last reset 00:01:32 ago, cause: software
      2022-09-04 20:45:03 [debug] Last software reset at 2022-09-04 20:43, reason: User, GCodes spinning, available RAM 9036, slot 2
      2022-09-04 20:45:03 [debug] Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      2022-09-04 20:45:03 [debug] Error status: 0x00
      2022-09-04 20:45:03 [debug] Step timer max interval 0
      2022-09-04 20:45:03 [debug] MCU temperature: min 34.5, current 35.3, max 35.7
      2022-09-04 20:45:03 [debug] Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      2022-09-04 20:45:03 [debug] Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
      2022-09-04 20:45:03 [debug] Events: 0 queued, 0 completed
      2022-09-04 20:45:03 [debug] Driver 0: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 1: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 2: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 3: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 4: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 5: standstill, SG min 0
      2022-09-04 20:45:03 [debug] Driver 6: standstill, SG min 0
      2022-09-04 20:45:03 [debug] Driver 7: standstill, SG min 0
      2022-09-04 20:45:03 [debug] Driver 8: standstill, SG min 0
      2022-09-04 20:45:03 [debug] Driver 9: standstill, SG min n/a
      2022-09-04 20:45:03 [debug] Driver 10:
      2022-09-04 20:45:03 [debug] Driver 11:
      2022-09-04 20:45:03 [debug] Date/time:
      2022-09-04 20:45:03 [debug] 2022-09-04 20:45:03
      2022-09-04 20:45:03 [debug] Cache data hit count 3337100654
      2022-09-04 20:45:03 [debug] Slowest loop: 20.33ms; fastest: 0.18ms
      2022-09-04 20:45:03 [debug] I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0
      2022-09-04 20:45:03 [debug] === Storage ===
      Free file entries: 9
      2022-09-04 20:45:03 [debug] SD card 0 detected, interface speed: 20.0MBytes/sec
      2022-09-04 20:45:03 [debug] SD card longest read time 1.0ms, write time 7.2ms, max retries 0
      2022-09-04 20:45:03 [debug] === Move ===
      DMs created 83, segments created 3, maxWait 12739ms, bed compensation in use: none, comp offset 0.000
      2022-09-04 20:45:03 [debug] === MainDDARing ===
      Scheduled moves 1, completed 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
      2022-09-04 20:45:03 [debug] === AuxDDARing ===
      2022-09-04 20:45:03 [debug] === Heat ===
      2022-09-04 20:45:03 [debug] Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
      2022-09-04 20:45:03 [debug] === GCodes ===
      2022-09-04 20:45:03 [debug] Segments left: 0
      2022-09-04 20:45:03 [debug] Movement lock held by null
      2022-09-04 20:45:03 [debug] HTTP is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Telnet is idle in state(s) 0
      2022-09-04 20:45:03 [debug] File is idle in state(s) 0
      2022-09-04 20:45:03 [debug] USB is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Aux is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Trigger is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Queue is idle in state(s) 0
      2022-09-04 20:45:03 [debug] LCD is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Daemon is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Autopause is idle in state(s) 0
      2022-09-04 20:45:03 [debug] Code queue is empty
      2022-09-04 20:45:03 [debug] === DueX ===
      Read count 1, 0.65 reads/min
      2022-09-04 20:45:03 [debug] === Network ===
      2022-09-04 20:45:03 [debug] Slowest loop: 146.51ms; fastest: 0.00ms
      2022-09-04 20:45:03 [debug] Responder states:
      2022-09-04 20:45:03 [debug]  HTTP(0)
      2022-09-04 20:45:03 [debug]  FTP(0)
      2022-09-04 20:45:03 [debug]  Telnet(0), 0 sessions
      2022-09-04 20:45:03 [debug] HTTP sessions: 2 of 8
      2022-09-04 20:45:03 [debug] = WiFi =
      Network state is active
      2022-09-04 20:45:03 [debug] WiFi module is connected to access point
      2022-09-04 20:45:03 [debug] Failed messages: pending 0, notready 0, noresp 0
      2022-09-04 20:45:03 [debug] WiFi firmware version 1.27beta1
      2022-09-04 20:45:03 [debug] WiFi MAC address 84:0d:8e:b2:f8:6f
      2022-09-04 20:45:03 [debug] WiFi Vcc 3.32, reset reason Turned on by main processor
      2022-09-04 20:45:03 [debug] WiFi flash size 4194304, free heap 24728
      2022-09-04 20:45:03 [debug] WiFi IP address 192.168.0.195
      2022-09-04 20:45:03 [debug] WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
      2022-09-04 20:45:03 [debug] Clock register 00002002
      2022-09-04 20:45:03 [debug] Socket states:
      2022-09-04 20:45:03 [debug]  0
      2022-09-04 20:45:30 [warn] HTTP client 192.168.0.40 login succeeded
      2022-09-04 20:45:30 [warn] HTTP client 192.168.0.207 login succeeded
      2022-09-04 20:46:19 [warn] HTTP client 192.168.0.40 login succeeded
      2022-09-04 20:46:20 [warn] HTTP client 192.168.0.207 login succeeded
      2022-09-04 20:46:32 [warn] HTTP client 192.168.0.40 login succeeded
      2022-09-04 20:46:34 [warn] HTTP client 192.168.0.207 login succeeded
      Static ram: 23860
      Tasks: NETWORK(ready,23.4%,211) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,304) DUEX(notifyWait,0.0%,24) MAIN(running,75.7%,446) IDLE(ready,0.9%,30), total 100.0%
      Owned mutexes:
      Error status: 0x00
      Driver 10:
      Driver 11:
      Date/time: 2022-09-04 20:45:03
      === Storage ===
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Code queue is empty
      === DueX ===
      === Network ===
      = WiFi =
        I see you're using the 3.4.2 RC3 which includes an updated wifi server 1.27 beta.
        Can you try flashing back to 3.4.1 using the full zip file to compare performance with the previous wifi server 1.26?
