    M675 not stopping when reaching X max
    CNC
    • Menthosundefined
      Menthos
      Hi, hopefully somebody knows what I’m doing wrong. I’m using the following to probe the cavity of an openbuilds XYZ probe:
      M675 X R8 F100 P0 ; Find center in X axis
      M675 Y R8 F100 P0 ; Find center in Y axis
      …and it moves and senses the X min, stops and then moves to sense the X max, but doesn’t stop. I’m hitting the estop.
      I can see the XYZ probe registering the contact (green light)
      Fingers crossed it’s something seen before.
      Menthosundefined 1 Reply Last reply Reply Quote 0
      • Menthosundefined
        Menthos @Menthos
        Sorted that bit - the 'R' setting was way too high... set it to 2 and that part works.
        dc42undefined 1 Reply Last reply Reply Quote 1
          dc42 administrators @Menthos
          @menthos I think the R value only needs to be high enough to guarantee that the probe stops registering contact after moving away from the minimum.
          Menthosundefined 1 Reply Last reply Reply Quote 1
          • dc42undefined dc42 marked this topic as a question
          • Menthosundefined
            Menthos @dc42
            @dc42 Ah, ok, that would make sense... I'd read that as being the amount of travel it did to 'find' the edge.
            Thanks!!
              @menthos I have updated the documentation at https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m675-find-center-of-cavity.
