    Duet3 mini 5+ on CR-10S Rediculously Slow Print Speeds (8mm/s)
    Using Duet Controllers
    the machine will home all axis
    • wmccoy61undefined
      wmccoy61
      Machine has been upgraded to 24V. I have a BL Touch installed and working. I have a BIQU H2 Direct drive Hotend Installed. I am using a 0.6 Nozzle. (Config File at end of Message)
      The machine will home all axis in a decent manner no problem. but once I star a print it drops into granny gear forever more... I know it's probably something I have set wrong, but I'm not figuring it out and decided to ask for some guidance. While I am not new to 3D printing, I am new to REPRAP.
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.12 on Sun Aug 28 2022 17:19:32 GMT-0400 (Eastern Daylight Time)
      M550 P"Creality CR-10S" ; set printer name
      M950 P1 C"io0.out"
      M950 P2 C"io2.out"
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards
      M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 D3 ; physical drive 0.2 goes forwards
      M569 P0.3 S0 D3 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 D3
      M584 X0.0 Y0.1 Z0.2:0.4 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E917.25 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z900.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00: E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E600 I50 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X-4 Y-25 Z0 S1 ; set axis minima
      M208 X310 Y300 Z400 S0 ; set axis maxima
      M574 X1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !^io5.in
      M574 Y1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^io6.in
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"io3.out" ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-15 Y-30 Z 1.7 ; set Z probe trigger value, offset and trigger height
      M557 X40:270 Y25:280 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H0 R0.209 K0.299:0.000 D6.89 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.740 K0.290:0.000 D14.05 E1.35 S1.00 B0 V24.3 ; disable bang-bang mode for heater and set PWM limit
      M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
      M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
      T0
      Cura Settings ? which ones do you need to know... Don't know how to dump them so I can show them all... But I suspect the slicer is the main culprit here..
        Phaedrux Moderator @wmccoy61
        @wmccoy61 said in Duet3 mini 5+ on CR-10S Rediculously Slow Print Speeds (8mm/s):
        Cura is likely set to marlin gcode flavor and/or your printer profile has some commands in the slicer start gcode section that is setting some very slow speed values.
        • wmccoy61undefined
          wmccoy61
          There was some extra code in the start code section that somehow got put back after I deleted it.. I edited the gcode to verify it wasw gone and printer is much better now/ Thanks!
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
