    CPU temp gone missing with 1.20beta1
    Firmware installation
    1.3k
    • greecherundefined
      greecher
      I got around to adding a fan to my cpu enclosure, and went to check cpu temp, but noticed it has gone missing from the Machine Properties page. I haven't jumped ship to the second beta because of noted issues for corexy, was wondering if this was oversight, me just not knowing where to look etc.
      • Martin_Sundefined
        Martin_S
        Locate the "Tools / Heaters / Extra" tab and clic on "Extra".
        MCU temp should be there.
        If it ain't broke, fix it till it is =)
        • greecherundefined
          greecher
          no such tabs exist, maybe its because of the alpha version of web server 1.20alpha1 which was a requirement of the firmware beta.
            Check which version of DWC you are running. If it's 1.19.3 then the Extra link will definitely be there, near the top left corner, just below the "Send GCode" box.
            • greecherundefined
              greecher
              here is my current install:
              Software Information
              Firmware Name: RepRapFirmware for Duet WiFi
              Firmware Electronics: Duet WiFi 1.0
              Firmware Version: 1.20beta4 (2017-10-28)
              WiFi Server Version: 1.20beta2
              Web Interface Version: 1.19.3
              Web Interface by Christian Hammacher
              Licensed under the terms of the GPL v3
              Dark theme kindly provided by Fotomas
              and here is a picture of the tools menu
              https://imgur.com/a/tqw8y
              So I think i have the latest everything, including the DuetWebControl 1.19.3, still no extra menu…
                I can see the "Extra" link near the top left in your image. You don't need to be on the Tools menu to get it, it's in the common area.
                • greecherundefined
                  greecher
                  doh, thank you for your patience with dolt users like me sometimes, totally misread where to look.
                    No problem, if I saw "Tools / Heaters / Extra" mentioned, I would assume that the"/" meant a sub-menu. But in this case, it didn't.
