    Wifi setup complited and connect to the computer
    Firmware installation
    • patelundefined
      patel
      I getting message 1) Attempt to move the head of a delta or scara printer before homing the towers. 2) massage from duet firmware ( config…)
      Firmware Name:
      RepRapFirmware for Duet WiFi
      Firmware Electronics:
      Duet WiFi 1.0
      Firmware Version:
      1.19.2 (2017-09-01)
      WiFi Server Version:
      1.19
      Web Interface Version:
      1.19
      Web Interface by Christian Hammacher
      Licensed under the terms of the GPL v3
      and one more think when I press x axis motor X-100. result rotate X,Y axis Motor both together
      M120
      G91
      G1 X-10 F6000
      M121
      Attempt to move the head of a Delta or SCARA printer before homing the towers
        You need to generate config.g and homing files to match your printer characteristics, and upload them to the SD card. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer. You can use this tool https://configurator.reprapfirmware.org/ to generate them.
