M950 should mention than S and P numbers are shared
I am not sure if this is a bug or if this is expected, but I have an
M950 S0
for my bltouch, and I tried to addM950 P0
for an IO output (water pump relay), and I had very weird behavior. I renumberedM950 P1
and the issue was gone.My conclusion is that
Px
andSx
parameters share "slots" and should not have the same number and this should be mentioned in the doc. -
@kuon Sorry for the slow reply. I added the following to the M950 description a while ago:
Pnn or Snn Output/servo pin number. Each P and/or S number needs to be unique, eg P1, P2, S3 P4, S5 etc. Servo pins are GpOut pins with a different default PWM frequency.
undefined droftarts marked this topic as a question
undefined droftarts has marked this topic as solved
