    ok my pulsed sensor problems
    Filament Monitor
    • broncosisundefined
      broncosis
      First off thanks for the great forum I have lurked for ages found 99% of answers I need with out posting
      I am currently using a duet2 wifi with a duex 5 running 3.4.4 firmware
      and everything has just worked for the most part
      I have built this sensor
      https://www.thingiverse.com/thing:3785514 with a 32 tooth encoder wheel
      chosen because I had all the parts on hand. and it is attached to my corexy (sel fsourced railcore) by reverse bowden I would rather not add the sensor to my carriage
      here is my most recent attempt to calibrate it
      2022-11-24, 7:07:42 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.050mm/pulse, measured minimum 27%, maximum 22844% over 5656.8mm
      2022-11-24, 7:00:26 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.100mm/pulse, measured minimum 27%, maximum 21655% over 4539.8mm
      2022-11-24, 6:59:57 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.108mm/pulse, measured minimum 27%, maximum 21655% over 4465.2mm
      2022-11-24, 6:55:37 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.185mm/pulse, measured minimum 27%, maximum 21655% over 4042.0mm
      2022-11-24, 6:55:28 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.184mm/pulse, measured minimum 27%, maximum 21655% over 4010.4mm
      2022-11-24, 6:55:21 p.m. 	M591 D0
      2022-11-24, 6:45:01 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.241mm/pulse, measured minimum 27%, maximum 2257% over 2132.1mm
      2022-11-24, 6:40:29 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.216mm/pulse, measured minimum 27%, maximum 2257% over 1199.8mm
      2022-11-24, 6:40:21 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.213mm/pulse, measured minimum 27%, maximum 2257% over 1173.6mm
      2022-11-24, 6:36:06 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.237mm/pulse, measured minimum 27%, maximum 2257% over 307.7mm
      2022-11-24, 6:35:41 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.182mm/pulse, measured minimum 27%, maximum 2257% over 212.8mm
      2022-11-24, 6:35:11 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.739mm/pulse, measured minimum 28%, maximum 51% over 122.6mm
      2022-11-24, 6:34:51 p.m. 	M591 D0
      Pulse-type filament monitor on pin zstop, disabled, sensitivity 0.250mm/pulse, allowed movement 50% to 200%, check every 5.0mm, measured sensitivity 0.743mm/pulse, measured minimum 32%, maximum 37% over 48.3mm
      2022-11-24, 6:34:37 p.m. 	M591 D0 P7 C"zstop" S0 R50:200 L0.25 E5 ;rotary optical sensor
      M122
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DLM-996AL-K65SN-6J9FD-3SN6P-TA16X
      Used output buffers: 1 of 26 (26 max)
      Static ram: 23860
      Dynamic ram: 76488 of which 40 recycled
      Never used RAM 8092, free system stack 92 words
      Tasks: NETWORK(notifyWait,30.8%,211) HEAT(notifyWait,0.1%,303) Move(notifyWait,6.9%,268) DUEX(notifyWait,0.0%,24) MAIN(running,61.8%,421) IDLE(ready,0.3%,30), total 100.0%
      Owned mutexes:
      Last reset 49:07:06 ago, cause: software
      Last software reset at 2022-11-22 17:45, reason: User, GCodes spinning, available RAM 9752, slot 2
      Error status: 0x14
      Step timer max interval 0
      MCU temperature: min 18.5, current 20.9, max 22.1
      Supply voltage: min 0.0, current 0.0, max 12.5, under voltage events: 4, over voltage events: 0, power good: no
      Heap OK, handles allocated/used 99/4, heap memory allocated/used/recyclable 2048/654/590, gc cycles 0
      Events: 5 queued, 5 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2022-11-24 20:44:06
      Slowest loop: 159.28ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 13.5ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 31, maxWait 1539ms, bed compensation in use: mesh, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 95975, completed 95975, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.7
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === DueX ===
      Read count 0, 0.00 reads/min
      === Network ===
      Slowest loop: 99.82ms; fastest: 0.07ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      Failed messages: pending 0, notready 0, noresp 49
      WiFi firmware version 1.27
      WiFi MAC address cc:50:e3:76:3f:a6
      WiFi Vcc 3.43, reset reason Software restart
      WiFi flash size 4194304, free heap 24320
      WiFi IP address 10.0.1.27
      WiFi signal strength -55dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      by my math which is probably wrong it should be about 1.2 mm per tooth on the encoder
      the designer had his set for around 0.83 mm per pulse
      at least this time around the Minimum value seems to be constant now but it is way out there on the max
      and the Measured sensitivity is pretty erratic as well
      this during a PLA print with relatively few retractions and only 0.6mm of retraction
      so any help would greatly be appreciated
        dc42 administrators @broncosis
        @broncosis my guess is that the sensor does not provide a sharp transition with sufficient hysteresis when the wheel moves between blocking and not blocking the sensor. So any slight vibration when the wheel is stationary at such a point or moving very slowly will register multiple pulses. This was a common problem with a particular type of sensor a few years ago, and the fix was to add a positive feedback resistor to the comparator circuit.
        broncosisundefined 1 Reply Last reply Reply Quote 0
          broncosis @dc42
          @dc42 thanks I am not a 100% sure where to put that
          but I did see a post about adding a resistor to their sensor they were using a different
          optical sensor than I am so I didn't think much of it
          and as its just a optical end stop I am using there's a good chance I need a better circuit al together
          but I will dig a little deeper thanks for direction.
