    Only probe where the part will be printed
    Gcode meta commands
    4.0k
    • Proschi3Dundefined
      Proschi3D
      I've read a lot here, but I can't really get it to work that the printer just probing where the printed part is before the start.
      I tried it with PS and S3D.
      Is there a guide for beginners somewhere?
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @Proschi3D
        @Proschi78
        This is how I do it.
        I have a macro to set my default probe points like you would normally do in config.g
        I have modified my mesh.g so if it's not called using specific parameters then it probes the whole bed as normal. This would happen if you did it from DWC for example.
        If the correct parameters are passed it just probes the print area.
        Prusa slicer start code
        M98 P"0:/sys/mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} N60 ; set N to your desired distance between probe points
        G29 S1  ; load small mesh
        0:/sys/setDefaultProbePoints.g
        Modify this to suit your bed
        ;0:/sys/setDefaultProbePoints.g
        ;setDefaultProbePoints.g
        M557 X30:170 Y10:170 P6 ; set up as you would normally in config.g
        0:/sys/mesh.g
        You can comment out the echo's when you're happy it's working.
        ;mesh.g
        M98 P"setDefaultProbePoints.g"
        if (exists(param.A) && exists(param.B) && exists(param.C) && exists(param.D) && exists(param.N))
        	var xDistance = (param.B - param.A)
        	var yDistance = (param.D - param.C)
        	var smallestRequired = min(var.xDistance,var.yDistance)
        	var probeDistance = floor(min(var.smallestRequired,param.N))
        	echo "Probe distance used:", var.probeDistance,"mm"
        	var xMin = max(move.compensation.probeGrid.mins[0],param.A)
        	echo "xMin = max(", move.compensation.probeGrid.mins[0],param.A,")"
        	var xMax = min(move.compensation.probeGrid.maxs[0],param.B)
        	echo "xMax = min(",move.compensation.probeGrid.maxs[0],param.B,")"
        	var yMin = max(move.compensation.probeGrid.mins[1],param.C)
        	echo "yMin = max(" ,move.compensation.probeGrid.mins[1],param.C,")"
        	var yMax = min(move.compensation.probeGrid.maxs[1] ,param.D)
        	echo "yMax = min(",move.compensation.probeGrid.maxs[1] ,param.D,")"
        	M557 X{var.xMin,var.xMax} Y{var.yMin,var.yMax} S{var.probeDistance}
        	if result != 0
        		echo "Points used X",var.xMin,":",var.xMax,"Y",var.yMin,":",var.yMax, " Spacing:", var.probeDistance
        		abort "Invalid M557 parameters"
        G29 S0
        var ProbeCenterX = (move.compensation.probeGrid.maxs[0] - ((move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0])/2)) ; calculate centre point of probe area
        var ProbeCenterY = (move.compensation.probeGrid.maxs[1] - ((move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1])/2)) ; calculate centre point of probe area
        G1 X{var.ProbeCenterX - sensors.probes[0].offsets[0]} Y{var.ProbeCenterY - sensors.probes[0].offsets[1]} Z{sensors.probes[0].diveHeight+2} F3600
        G30
        Proschi3Dundefined 3 Replies Last reply Reply Quote 3
          Proschi3D @OwenD
          @OwenD Thank you for your help,
          i will try this afternoon
          did someone manage it already with S3D?
            Proschi3D @OwenD
            This post is deleted!
              Proschi3D @OwenD
              @OwenD the mesh works but printing is canceled
              	Extruder pressure advance: 0.065, 0.000
              Error: in file macro line 7 column 7: M140: expected number after 'S'
              Error: Bad command: mperature]
              Error: in file macro line 8 column 11: M190: expected number after 'r'
              Error: in file macro line 9 column 11: M109: expected number after 'r'
              Error: Bad command: mperature] T0
              Error: in file macro line 4 column 39: meta command: expected numeric operands
              Cancelled printing file 0:/gcodes/Part 27 - Part 2.gcode, print time was 0h 2m
              20.12.2022, 17:17:40	4 points probed, min error -0.233, max error -0.025, mean -0.132, deviation 0.078
              Height map saved to file 0:/sys/heightmap.csv
              20.12.2022, 17:17:28	Probe distance used: 60 mm
              xMin = max( 15.0 121.681 )
              xMax = min( 325.0 213.662 )
              yMin = max( -15.0 75.8219 )
              yMax = min( 210.0 153.294 )
              20.12.2022, 17:14:32	Connected to 192.168.178.91
              • OwenDundefined
                OwenD @Proschi3D
                @Proschi78
                The M140, M190 & M109 commands that are causing the errors are in your code, not mine.
                Most likely in your start G Code
                It looks like you're using incorrect place holders for the temps
                Please post the start GCode from Prusa Slicer
                Proschi3Dundefined 1 Reply Last reply Reply Quote 0
                  Proschi3D @OwenD
                  @OwenD
                  PS start code
                  M703		; Load Filament specific config, including Temps
                  M98 P"/sys/start/Prusalinks"
                  Macro
                  T0
                  M572 D0 S0.065
                  M572 D1 D0.065
                  G90 ; set printer absolute mode
                  M82 ; set extruder to absolute mode
                  M106 S0 ; fan off
                  ;M98 P"0:/sys/mesh.g" A{first_layer_print_min[0]} B{first_layer_print_max[0]} C{first_layer_print_min[1]} D{first_layer_print_max[1]} N60 ; set N to your desired distance between probe points
                  G28 ; home all axes
                  G28 Z0
                  G29
                  G29 s1
                  T0 ; set first toolhead
                  G1 Z3 F2000 ; Move to Z3 for height clearance before Intro line
                  G92 E0 ; set position
                  ; intro line
                  T0
                  G1 Z0.35 F6000 ;
                  G1 X60 Y-2 F6000 ;
                  G1 X140 Y-2 E20 F200 ;
                  G1 x160 y-2 F5000
                  G1 Z5 F2000 ; Move to Z5 to prevent dragging nozzle and scratching bed
                  G1 x170 y-2 F2000
                  G1 F9000.0 ;
                  M117 Printing...
                  • OwenDundefined
                    OwenD @Proschi3D
                    @Proschi78
                    Where are you setting your temps?
                    If it's in your filament config.g then post that too.
                    If you don't put heater settings in PS start code, it will probably do it for you.
                    So if you want to set your temps in the filament config.g then put a dummy setting in your PS start code.
                      Proschi3D @OwenD
                      @OwenD
                      Extruder pressure advance: 0.065, 0.100
                      Error: in file macro line 6 column 59: meta command: expected numeric operands
                      Cancelled printing file 0:/gcodes/Part 27 - Part 1.gcode, print time was 0h 0m
                      20.12.2022, 20:56:33	M32 "0:/gcodes/Part 27 - Part 1.gcode"
                      File 0:/gcodes/Part 27 - Part 1.gcode selected for printing
                      T0
                      M572 D0 S0.065
                      M572 D1 D0.065
                      M106 S0 ; fan off
                      G28 ; home all axes
                      G28 Z
                      G29
                      G29 S1
                      T0 ; set second toolhead
                      ; intro line
                      G1 Z0.35 F6000 ;
                      G1 X60 Y-2 F6000 ;
                      G1 x160 y-2 F5000
                      G1 x170 y-2 F2000
                      G1 F9000.0 ;
                      M106 P3 S33
                      M117 Printing...
                      • OwenDundefined
                        OwenD @Proschi3D
                        @Proschi78
                        I'm unsure where the code you have posted is located.
                        Please try the following in your Prusa Start GCode.
                        Don't call any other macros from Prusa!
                        M118 S"Begin slicer start g code"
                        ;M104 S0 R0 P{current_extruder} ;Dummy  Set temps to zero to stop slicer adding them
                        T{current_extruder} ; select tool used on first layer
                        M703 ; load config file for [filament_type]
                        G90 ; Switch to using Absolute Coordinates
                        M568 P{current_extruder} R{"{heat.coldExtrudeTemperature+5}"} S{first_layer_temperature[current_extruder]} A1 ; (set extruder to stanby to soften any protruding filament before probing )
                        M106 P{current_extruder} S0 ;Start with fan off
                        M118 S"Heating Bed"
                        G4 S1
                        M140 S{first_layer_bed_temperature[current_extruder]}  R{bed_temperature[0]-20}; Set fast bed temp & standby - Standby is 20 degrees less than normal.
                        M116 ; Wait for bed before doing mesh probe.
                        M291 S0 T3  P"Homing..."
                        G28 ; Home all
                        M400 ; wait for last move
                        ; intro line
                        G1 Z0.35 F6000 ;
                        G1 X60 Y-2 F6000 ;
                        G1 x160 y-2 F5000
                        G1 x170 y-2 F2000
                        G1 F9000.0 ;
                        M106 P3 S33
                        M117 Printing...
                          Proschi3D @OwenD
                          @OwenD
                          20.12.2022, 21:53:49	M32 "0:/gcodes/Part 27 - Part 2.gcode"
                          File 0:/gcodes/Part 27 - Part 2.gcode selected for printing
                          Heating Bed
                          If I exclude M98 then normal mesh leveling and printing work.
                          M118 S"Heating Bed"
                          G4 S1
                          G28 ; Home all
                          G29
                          ; intro line
                          G1 Z0.35 F6000 ;
                          G1 X60 Y-2 F6000 ;
                          G1 x160 y-2 F5000
                          G1 x170 y-2 F2000
                          G1 F9000.0 ;
                          M106 P3 S33
                          M117 Printing...
                          danym21undefined 1 Reply Last reply Reply Quote 0
                          • danym21undefined
                            danym21 @Proschi3D
                            @Proschi78
                            Hi, I use SuperSlicer, but I think in prusa Slicer it should also work.
                            in my startcode I added this line:
                            M557 X{first_layer_print_min[0]}:{first_layer_print_max[0]} Y{first_layer_print_min[1]}:{first_layer_print_max[1]}
                            maybe this will help you too.
                              Proschi3D @danym21
                              @danym21 Error: in GCode file line 182 column 7: M221: expected number after 'S'
                              Error: in file macro line 8 column 8: M557: unknown value 'first_layer_print_min^'
                              can you give me your whole start code ?
                              and mesh.g ?
                              • danym21undefined
                                danym21 @Proschi3D
                                @Proschi78
                                start G-Code:
                                G90 ; use absolute coordinates
                                ;M83  ; extruder relative mode
                                ;BED_MESH_CALIBRATE AREA_START={first_layer_print_min[0]},{first_layer_print_min[1]} AREA_END={first_layer_print_max[0]},{first_layer_print_max[1]}
                                ;MINX:{first_layer_print_min[0]}
                                ;MINY:{first_layer_print_min[1]}
                                ;MAXX:{first_layer_print_max[0]}
                                ;MAXY:{first_layer_print_max[1]}
                                M82 ; absolute extrusion mode
                                M104 S140 T0
                                M140 S[first_layer_bed_temperature] ; set bed temp
                                M190 S[first_layer_bed_temperature] ; wait for bed temp
                                G32 ; home all
                                G1 X-14 Y-10 F10000
                                ; Reset speed and extrusion rates
                                M200 D0 ; disable volumetric e
                                M220 S100 ; reset speed
                                M221 S100 D0 ; reset extrusion rate
                                M109 S{first_layer_temperature[initial_extruder]+extruder_temperature_offset[initial_extruder]} ; wait for extruder temp
                                G92 E0.0
                                ;G1 X150.0 E20  F1000.0 ; intro line
                                G1 E20  F1000.0 ; intro line
                                G1 X0.0 Y0.0 Z0.1 F1000.0 ; go outside print area
                                ;G1 X5 Y0
                                G92 E0.0
                                G1 X2 Y2 Z0.2 E0 F18000 ; new
                                G1 X60 Y2 E9.0 F1800 ;intro Line
                                ;G1 X200.0 E30 F500 ; second Part intro Line
                                G92 E0.0
                                G1 Z5 E-{retract_length[0]} F{retract_speed *60}
                                G1 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} Z{first_layer_height} F30000
                                G1 E{retract_length[0]} F{retract_speed*60}
                                G92 E0.0
                                I do not use a mesh.g this does not exists on my system
                                my bed.g:
                                ; bed.g
                                ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 01:08:02 GMT+0100 (Mitteleuropäische Normalzeit)
                                G4 P100
                                G28 ; home
                                G0 Z10 F4200
                                G0 F60000
                                G30 P0 X5 Y155 Z-99999						;Orbiter
                                G30 P1 X302 Y155 Z-99999 S2					;Orbiter
                                G91 										;Relative positioning
                                G1 Z5 F1500 								;Raise Z 5mm
                                G90 										;Absolute positioning
                                G0 X45 Y-5 F60000
                                G29 										;Probe the heatbed and generate heightmap
                                G4 P100
                                G0 X0 Y0 F60000 						;Go to Parking Position
                                some settings in config.g that maybe relevant for:
                                M671 X-52:377 Y155:155 S2.5 					   ; leadscrews at left (connected to Z) and right
                                M557 X10:300 Y10:300 P6:6; S40                     ; define mesh grid ( the normal full size mesh config)
                                Proschi3Dundefined 2 Replies Last reply Reply Quote 1
                                  Proschi3D @danym21
                                  jetzt gehts 🙂
                                  now it works 🙂
                                  • danym21undefined
                                    danym21 @Proschi3D
                                    @Proschi78
                                    Proschi3Dundefined 1 Reply Last reply Reply Quote 1
                                      Proschi3D @danym21
                                      @danym21 Do you also have start codes for other slicers?
                                      • danym21undefined
                                        danym21 @Proschi3D
                                        @Proschi78
                                        no, sorry
                                        but on S3d maybe have a look to this variables:
                                        I do not know what is in, but you can test with a smal object and check then the gcode file
                                        [build_size_x]
                                        [build_size_y]
                                        [build_size_z]
                                        [next_position_x]
                                        [next_position_y]
                                        [next_position_z]
                                        they are mentioned here:
                                        https://community.ultimaker.com/topic/11328-simplify3d-hidden-undocumented-placeholders-for-post-processing-scripts/
                                          Proschi3D @danym21
                                          @danym21 thanks I'll test that tomorrow
                                            Proschi3D @danym21
                                            @danym21 said in Only probe where the part will be printed:
                                            @Proschi78
                                            start G-Code:
                                            M104 S140 T0
                                            G32 ; home all
                                            G1 X-14 Y-10 F10000
                                            G92 E0.0
                                            ;G1 X5 Y0
                                            G92 E0.0
                                            G92 E0.0
                                            G92 E0.0
                                            my bed.g:
                                            ; bed.g
                                            G4 P100
                                            G28 ; home
                                            G0 Z10 F4200
                                            G0 F60000
                                            G0 X45 Y-5 F60000
                                            G4 P100
                                            what can I do with this start code so that it is probing in mesh like A5 in normal mesh?
                                            Best off five ?
