BtnCmd & multiple devices
Im using a Mini 5+ wifi for a custom multi head Cartesian machine. BtnCmd has been awesome for setting up a custom UI macro controller. The problem is Im creating the BtnCmd Tab on my PC which is very easy to setup and config the Tab, but when I go to use the machine in situ with a dedicated 8" tablet my custom DWC/BtnCmd Tab is not there...
How do I make/setup/save BtnCmd tabs that will be available across all devices; pc, tablets, ph...?
@MintyTrebor Perfect, I just exported locally to file, emailed to the device, imported on the device and now just a matter of scaling the controls. So much faster!
Now I have a saved copy for cache clears. Thanks a ton, a wonderful plugin you've got there!
undefined wayneosdias marked this topic as a question
undefined wayneosdias has marked this topic as solved
